Hotmail & MSN
born2winu2
I am using the following config file for CISCO 1841 router....I can browse internet but my MSN messanger and hotmail is not working.
Paragon>
Paragon>
Paragon>en
Paragon#sh runn
Paragon#sh running-config
Building configuration...
Current configuration : 1344 bytes
version 12.4
hostname Paragon
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip name-server x.x.x.x
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
bba-group pppoe global
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/50
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username *** password ***
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
webvpn cef
end
Paragon#
Paragon#
7 Replies 7
interface dialer1
ip access-group 101 in (you forgot.....)
The default is to allow any traffic on a interface. Putting a access list in to permit all traffic will not have any effect other than make the router use cpu looking at it.
This problem I suspect is more related to this type of program and issues it has with embedding the pc address in the data stream when the pc is using a private address that will be natted to a public address. Many times options can be changed in the software to tolerate a natted address.
The basic configuration is correct it may just need a static nat but hard to say if both these packages do not run at all.
I think I have to change access-group 101 to 100 or 102....anyways...
can you tell me clearly what you means....
I am not getting you probably.
Warm Regards
The nat you are using only creates entries on traffic that comes from your internal machine as it flows out to a external machine on the internet. Once it is created it will allow traffic to return from the external machine.
If the external machine want to start communication with your machine there is nothing in the router to tell it how to translate the address and ports. You will need to put in static nat entries
ip nat inside source static tcp xxx.xx.x.x ???? interface dialer1 ????
You will need to find the ports for the applications you need.
Now this does not fix the issue that MSN can have. What MSN does is some cases it will put the local address of the machine inside a data packet and send it to the far side. The far side will then use that address to attempt a return session rather than use the address of the session that he received it on.
Not much you can do about the above. These issues have been fixed mostly with option in the software but there is little you can do with a router if the application is being stupid.
Danilo Dy
try setting the mtu to 1200
ignacio.corral
MTU by default to 1500 in dialer 1
you can try this command in interface LAN
ip tcp adjust-mss 1440
