How can I add a second PBR to an existing PBR
benedicto.rosa
I was given a task to add a PBR to my firewall. I have done this in the past but not to add an additional PBR to use the same interface to route out. Can I do this? If so, can someone please lead me in the right direction. Thank you
only add another line to PBR
route-map mhm permit 10
route-map mhm permit 20
this way
balaji.bandi
YES / NO - Its all depends what config you have in the existing setup.
You also need to provide more information like below :
what Firewall ?
what Code running ?
what is exiting PBR Looks like ?
what is your intention of the new one you are looking to do? ( some of of your views)
If you are using ASA check below example : (Examples for Policy Based Routing)
https://www.cisco.com/c/en/us/td/docs/security/asa/asa94/config-guides/cli/general/asa-94-general-config/route-policy-based.html
Note: Wrongly configured PBR has a significant impact on the network.
BB
Hello
I assume you mean an addtional set commands correct? - is so then Yes.
However you need to be mindfull the order you submit those addtional set commnads the route-map stanza WILL re-order them.
Kind Regards
Paul
