How can I check if my 877 is adsl synched ?
mediomen27
Hi I have bought a used 877 modem/router.
I am trying to configure it as I am a newbie. I have tried many different configuration but now I have some doubts if the modem really works. The first thing I need to know is if it can make the adsl synching... I need of some configuration or just to plug the rf11 in the router ?
a "sh dsl interface atm0" says the modem is down. The CD led is blinking.
How can I check if the adsl signal is synched ?
Hello
Have been be provided with any details regarding your ADSL connection from you isp
PPPoA/PPPoE settings -Would you know what mode your xDSL connection is? As this will define the configuration required on your router
res
paul
Kind Regards
Paul
Hi Paul,
thank you for your reply.
Well, in my supermarket-modem I see
ADSL2+
annex_a
it's an 8 mega adsl
pcv 8/36,  atm qos  ubr pcr 0,
dynamic ip, encapsulation 1483 bridged ip llc,
mtu 1492,
I dont see any clue about pppoa or pppoe.
googling looking for other infos about my provider (fastweb in italy) I found those:
Modulation: G.992.1 Annex A (G.dmt)
Latency: Fast
Multiplexing: LLC-based
encapsulation: Bridged (RFC-1483/RFC-2684)
Data Channel
VPI: 8
VCI: 36
Traffic Class: UBR
Thank you again for your help..
mediomen27
If I type "sh dsl int"
it says the modem is down,
dsl mode = unknown
and
Line has not yet been activated
My question is: can the configuration make problems to the dsl synching ?
or the dsl synching is something that it is or it is not ??
mediomen27
I want add an other info. The firmware is 12.4.15.t7 and the modem firmware version is 3.0.14.
Maybe I need to upgrade ? to what version ?
