how can i deny access in one direction, but not the other? (pkt)
meimeimei
I'm sorry to bother you all, but I'm having some issues with the network I'm building in CISCO Packet Tracer.
In my network, I need to deny access from one direction but not the other. For instance, in my network, I need the VLAN 20 (172.16.8.0 /24), VLAN 30 (172.16.9.0 /24), VLAN 40 (172.16.10.0 /24) and VLAN 50 (172.16.0.0 /21)  to be blocked from accessing the VLAN 10 (172.16.11.0 /27), but not vice versa; 172.16.11.0 /27 must still be able to ping those networks, but those networks must not be able to ping 172.16.11.0 /27.
I initially tried doing this using ACLs on the MainRouter, but that did not work at all as packets were able to ping in both directions even when I added ACL to a particular interface.
Does anyone know what my issue might be, and what should I do in order to fix it? Should i use other network security protocol? Any help would be much appreciated.
18 Replies 18
For icmp
Allow icmp reply and deny all other traffic
Apply this acl with IN direction.
MHM
Blue_Bird
If you want to deny access only in one direction...you should configure Extended acl. Standard acl blocks two-way communication and Extended acl blocks one way communication...
Here is the sample configuration....
ip access-list 101 deny icmp any 172.16.11.0 0.0.0.31 eq echo
ip access-list 101 permit ip any any
ip access-group 101 in
Best regards
******* If This Helps, Please Rate *******
in what interface should i put the ACL? is it in interface g0/1.10? the one who handles the VLAN 10?
Apply to interface that direct connect to subnet you want to protect.
MHM
I tried that but it is still pinging in both direction.
Share config I will check
MHM
here:
ip dhcp pool Administration
network 172.16.11.0 255.255.255.224
default-router 172.16.11.1
dns-server 172.16.12.3
ip dhcp pool 4thFloor
network 172.16.10.0 255.255.255.0
default-router 172.16.10.1
ip dhcp pool Guest
network 172.16.0.0 255.255.248.0
default-router 172.16.0.1
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524R5DB-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
ip access-group FILTER-ADMINISTRATION-VLAN-ACCESS in
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 172.16.11.1 255.255.255.224
ip helper-address 172.16.11.1
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 172.16.10.1 255.255.255.0
ip helper-address 172.16.10.1
interface GigabitEthernet0/1.50
encapsulation dot1Q 50
ip address 172.16.0.1 255.255.248.0
ip helper-address 172.16.0.1
interface GigabitEthernet0/2
ip address 172.16.12.1 255.255.255.0
ip access-group DENY-OTHER-VLANS-TO-ACCESS-THE-FILE-SERVER out
duplex auto
speed auto
interface Serial0/0/0
description Link to 2ndFloor_Router
ip address 172.16.11.34 255.255.255.252
interface Serial0/0/1
description Link to 3rdFloor_Router
ip address 172.16.11.38 255.255.255.252
interface Vlan1
no ip address
shutdown
interface Vlan50
mac-address 0060.70e5.0a01
no ip address
router rip
version 2
network 172.16.0.0
ip classless
ip flow-export version 9
ip access-list extended ONLY-ALLOW-VLAN-20-TO-ACCESS-THE-FILE-SERVER
permit ip 172.16.8.0 0.0.0.255 host 172.16.12.2
ip access-list extended DENY-OTHER-VLANS-TO-ACCESS-THE-FILE-SERVER
deny ip 172.16.0.0 0.0.7.255 host 172.16.12.2
deny ip 172.16.9.0 0.0.0.255 host 172.16.12.2
deny ip 172.16.10.0 0.0.0.255 host 172.16.12.2
deny ip 172.16.11.0 0.0.0.31 host 172.16.12.2
permit ip any any
ip access-list extended FILTER-ADMINISTRATION-VLAN-ACCESS
deny ip 172.16.0.0 0.0.7.255 172.16.11.0 0.0.0.31
deny ip 172.16.8.0 0.0.0.255 172.16.11.0 0.0.0.31
deny ip 172.16.9.0 0.0.0.255 172.16.11.0 0.0.0.31
deny ip 172.16.10.0 0.0.0.255 172.16.11.0 0.0.0.31
permit ip 172.16.11.0 0.0.0.31 172.16.0.0 0.0.7.255
permit ip 172.16.11.0 0.0.0.31 172.16.8.0 0.0.0.255
permit ip 172.16.11.0 0.0.0.31 172.16.9.0 0.0.0.255
permit ip 172.16.11.0 0.0.0.31 172.16.10.0 0.0.0.255
deny ip any any
line con 0
line aux 0
line vty 0 4
login
end
I think I get issue here
Change direction to be
OUT not IN
MHM
to the int g0/1.10, right? it fails.
the interface where  traffic from source entering to the router...
Best regards
Extended ACL's should be configured on closer to source...and apply on interface g0/1.10 in bound direction...
if sources(vlan 20,30,40,& 50) are available/connected on two different routers(2nd floor and 3rd floor)....you should configure two extended acl's... one... acl on  each router....
Please post the configuration...it might be helpful....
Best regards
here's the configuration for the main router:
ip dhcp pool Guest
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan50
no ip address
router rip
version 2
network 172.16.0.0
ip classless
permit ip any any
deny ip any any
line con 0
line aux 0
line vty 0 4
login
end
Blue_Bird
Remove all acl's if you configured any other routers...for example..
Router(config)# no access-list 101
Router(config-if)# no ip access-group 101 in|out
implement following acl in 2nd Floor router....
ip access-list 101 deny icmp 172.16.8.0 0.0.0.255 172.16.9.0 0.0.0.31 eq icmp
Interface Gig0/1
Note: There is no difference applying ACL on physical or sub interface as ACL is layer 3 and 4, not lower layer, hence doesn't make any diffrence applying it on the physical or sub interface.
after that try to ping from vlan 20 pc to vlan 10 pc you shouldn't see the communication...
but when you try to ping from vlan 10 pc to vlan 20 you should see successful communiation....
if you achive this for one vlan same way we can implement other vlans...
Best regards
the ping were still successful in both direction
