How can I set bandwidth on MPLS L2L
silviorodrigues
Dears good morning!
I have this tunnel how can we see in this picure! I need limit bandwith in 2 Mb, how can I do that?
Thanks!
5 Replies 5
Giuseppe Larosa
Hello Silvio,
you need to limit the traffic that can use the LSP built by LDP protocol for example L3VPN traffic you need to apply QoS on PE-CE link(s).
You can also mark the user traffic and you can see this propagated to EXP bits of MPLS frame
What is the usage you are looking for ?
Hope to help
Giuseppe
Giuseppe!
Thanks for your help! Actually I think that I need create a Pseudowire to limit the band, But I dont known how do that!
Hi Silvio,
you already have a pseudowire...
from what you posted you have an EoMPLS AtoM configuration.
so I expect under fast0/1.30 something like
xconnect x.x.x.x 130 encapsulation mpls  (x.x.x.x is the next hop you hid)
where VC 130 is your PW
depending on the platform you might attach a service-policy to Fa0/1.30 shaping/policing the traffic to 2Mb.
regards,
Riccardo
Hi Ricardo!
Im use in both side routers cisco 2801 with IOS "c2801-spservicesk9-mz.124-24.T.bin"!
My configuration is only this:
Side Client: (Where I need apply a Bandwidth to 2Mb)
interface FastEthernet0/1.30
xconnect 192.168.0.1  encapsulation mpls
Side ISP:
xconnect  192.168.2.1 encapsulation mpls
With this, could you show me a sample configuration?
Thanks!
Hi Silvio,
from what I remember policing is supported for AToM on ISR routers.
just attach a service policy policing your traffic to 2Mb to fa0/1.30
policy-map POLICE_2MB
class class-default
    police cir 2000000
int fa0/1.30
service-policy input POLICE_2MB
that should do it but you have to test that yourself
regards,
Riccardo
