ASA 8.4 Cant ping external hosts from inside
the-lebowski
Level 4
Level 4
DNS resolution works and I can surf the web without fail.  But if I try to ping any external hosts (I can ping inside interface of ASA fine) from the LAN I get timeouts.  I can ping anything from the ASA without fail.   Can someone help me out?
ASA Version 8.4(1)
hostname fw1-nat-ann
domain-name inmd.infoblox.com
enable password anWLNen9CTFp7B/X encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
speed 10
duplex full
nameif outside
security-level 0
ip address 38.104.12.98 255.255.255.252
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.23.1.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 172.23.18.198 255.255.255.0
management-only
boot system disk0:/asa841-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EST recurring
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server 172.23.16.21
object network obj_any
subnet 0.0.0.0 0.0.0.0
host 172.23.16.19
description INMD DC/RADIUS
object network INMD_ClientVPN
subnet 172.23.2.0 255.255.255.0
object network ............
host 172.23.18.20
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
protocol-object udp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
object-group protocol DM_INLINE_PROTOCOL_3
protocol-object ip
access-list inside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any any
access-list outside_cryptomap extended permit ip object Annapolis object SantaClara_HQ
access-list IPv4_VPN_HQGrpPolicy extended permit ip any any
access-list outside_cryptomap_2 extended permit ip object Annapolis object SSpeer_home
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-642.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static Annapolis Annapolis destination static INMD_ClientVPN INMD_ClientVPN
nat (inside,outside) dynamic interface
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 38.104.12.97 1
route inside 10.120.0.0 255.255.0.0 172.23.1.2 1
route inside 172.23.0.0 255.255.0.0 172.23.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server RADIUS protocol radius
aaa-server RADIUS (inside) host 172.23.16.19
timeout 5
key *****
aaa authentication ssh console LOCAL
http server enable
http 172.23.18.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map 3 match address outside_cryptomap_2
crypto map outside_map 3 set pfs
crypto map outside_map 3 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint ASDM_TrustPoint0
enrollment terminal
crl configure
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5
prf sha
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 management
ssh timeout 10
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
anyconnect image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 2
anyconnect enable
tunnel-group-list enable
wins-server none
dns-server value 172.23.16.21 172.23.18.23
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:bf287150b0604fdb0e77da531f04fc2b
: end
manish arora
Level 6
Level 6
Try :-
asa(config)# fixup protocol icmp
Manish
