How can use other addresses in my /28 PPPoE connection?
d-fillmore
Level 2
Level 2
We currently have an office in Tokyo that connects to the ISP using a PPPoE connection on an ASA. The ISP has supposedly assigned us a public /28, but I can't work out how to use any of the addresses other than the one that we use on the outside of firewall (which is part of this /28 block)
I tried to configure the IP address on the outside interface with a /28 mask, but it just reset the interface and changes the config back to a 32 bit mask
ip address X.X.X.X 255.255.255.255 pppoe setroute
We're going to replace the firewall with a router of some sort and have that do the PPPoE, but I don't know if I'll have the same problem.
Does anyone know how I can use these other addresses?
Will a router only be able to use a /32 address on the dialer?
Would I even be able to subnet the /28 down and host a /29 or something beind the router (when installed)?
Many Thanks in advance
Dom
ryates_presido
They are probably using a sticky static for your device connected to them and then routing your network down that interface. So you should be able to use the /28 on the back side of the router off a different Ethernet port or another port off the Asa.
ryates_presido
Thanks for the reply Ryates, I havae split the /28 in half and can route to one half of it if I configure it behind the ASA, which is great.
You said that should be able to route to the whole /28 behind the firewall - If I split the subnet in half, the address assigned to the outside by PPPoE is in the top half of the subnet, which is why I configured thee bottom half beghind the firewall.
Are you saying that I should be able to have the /32 address on the outside, and the the whole /28 behind the firewall? The addresses will be overlapping but these sort of connections seem to work in strange ways (eg a default route not on the same subnet) so nothing would surprise me
Cheers, Dom
You can use static nat on your router. or you can assign nat pool and add nat rule to use it. this is probably better than assigning the /28 to your Fast Ethernet port for so you don't loose 2 IP addresses and it would be easier to change public IP address assignements.
Don't forgrt to rate useful answers.
Hi Iyad, thanks for your suggestion, but I want to have the routeable public subnet behind the firewall/router as I need to host some third party eqpt there that needs to be on the internet
