How could I calculate the power consumption of 2900 series routers in VA?
mert1907er
I want to calculate the power consumption of the 2901 and 2911 routers when one WIC2T board is installed in terms of VA?
I looked at the Cisco calculator but there are only some models for some Cisco Switches and no routers. I can not find any information about the
power factor that I can use. Also, I don't know if the values in the datasheet like the "max power consumtion(W) = 150" are the values of the power supply or the actual real time usage values of the router. For instance, a power supply may be 250W and a router with minimum configuration may only use a maximum of 100W.
Any help would be appreciated. Thank you in advance.
nagasheshu2010
Please try show environment all command and look at the system power section, this might help.
SYSTEM POWER
Motherboard Components Power consumption = 46.6 W
Total System Power consumption is: 46.6 W
Sheshu.
