How do I change the selected/default Path of OSPF
Rock Knot
How do I change the default path so that
R1 go to R3 via
R1 > R4 > R6 > R3
and R2 go to R3 via
R2 > R4 > R5 > R7 > R6 > R3
Giuseppe Larosa
Hello @Rock Knot ,
you will need PBR Policy Based Routing to achieve what you want.
R1 and R2 both connect to R4 and from OSPF point of view only the destination counts so the best path to R6 is chosen regardless of the source . To take in account the source you need to use PBR that moves away from destination based routing and allows to make traffic sourced from  R2 to be sent from R4 to R5.
PBR has to be applied inbound on R4 on R4 to R2 link.
Edit:
in addition
ip ospf cost
has to be increased on link between R4 and R5 to avoid to have to implement PBR on R5 too.
Hope to help
Giuseppe
M02@rt37
Hello @Rock Knot,
You can change the cost metric on specific interfaces to influence OSPF path selection. Lower costs are preferred. This can be done using the
ip ospf cost
 command in interface configuration mode.
Best regards
Giuseppe Larosa
Hello @Rock Knot ,
Edit:
in addition
ip ospf cost
Hope to help
Giuseppe
Joseph W. Doherty
A possible alternative to what @Giuseppe Larosa describes might be to set up a tunnel between R2 and R5.
