How do I find out the AS number my eBGP neighbour is using to peer with me?
lucy.west
Hi - is there a way of finding out what AS number an EBGP peer is using to peer with my router? Obviously do a debug and reset the BGP peers, but I wondered if there's any 'show' command which can show me the same thing?
Note - I don't mean the neighbour's AS number but my own router's!
6 Replies 6
rajib_das
Hi lucy,
you can see the AS number of neighbor with "show ip bgp Summary" command
rajib
Hi - I'm actually after finding out my own AS number that they're peering with: my router's part of a subconfederation.
I know i'd see this in a debug of the OPEN message when establishing neighbours - I just wondered if there's another way of seeing it without resetting the neighbour?
ta
cisco_lad2004
Level 5
Level 5
in addition to previous reply....u will get error message if u trying configure a differnet AS, I dont recommend it in case cisco removed this safety pin and allows the reconfig on a new AS :-)
TST-POP1-NPE01(config)#router bgp 65001
BGP is already running; AS is 64512
Hi - thanks but I'm trying to find out the AS number of my own router that they're peering with. I have subconfederation configured: if I did a debug on BGP and reset the peers then I think we'd see it with the OPEN BGP message, is there another way to see if without resetting peers/debug?
Hello Lucy,
to see the AS number as seen by others do
sh run | beg router bgp
and look at the line that say
bgp confederation identifier that is the public AS number you are looking for
Hope to help
Giuseppe
OK thank you
