How do I make my tunnel work?
Assuming I did everything else right...what might I be missing?
R2 and R3 have been configured with physical IPv4 addresses/Loopbacks and each also has an IPv6 Loopback simulating an internal network.
I even configured the Tunnels on each Router with their own IPv6 address.
All three Routers are running OSPF and while only R2 and R3 are running OSPFv3...with all their IPv6 addresses, including the tunnels, being incorporated into the Routing.
R2 and R3 still don't know about each other.
Obviously R1 has no IPv6 information but in all the demonstrations, I never saw the MIDDLE router having to be configured with anything that R2 and R3 do.
What should I do?
I implemented your scenario in a simulator. Please try this config and give me the result. Please see the result of ping attached. Redistribute is not needed. I put it just in case.
R1
hostname R1
ipv6 unicast-routing
interface Loopback1
 ip address 1.1.1.1 255.255.255.0
interface Loopback101
 ipv6 address 2001:101:101:1::1/64
 ipv6 ospf 111 area 0
interface Tunnel1
 ipv6 address 2001:404:404:4::4/64
 tunnel source 1.1.1.1
 tunnel destination 2.2.2.2
interface Serial1/0
 ip address 192.40.0.28 255.255.255.0
 encapsulation ppp
router ospf 3
 log-adjacency-changes
 network 1.1.1.0 0.0.0.255 area 0
 network 192.40.0.0 0.0.0.255 area 0
ipv6 router ospf 111
redistribute connected
R0
interface Serial0
 ip address 192.40.0.27 255.255.255.0
 encapsulation ppp
interface Serial1
 ip address 23.0.2.5 255.255.255.248
 encapsulation ppp
router ospf 1
 network 0.0.0.0 255.255.255.255 area 0
R2
hostname R2
interface Loopback2
 ip address 2.2.2.2 255.255.255.0
interface Loopback202
 no ip address
 ipv6 address 2001:202:202:2::2/64
 ipv6 ospf 222 area 0
interface Tunnel1
 no ip address
 ipv6 address 2001:404:404:4::3/64
 tunnel source 2.2.2.2
 tunnel destination 1.1.1.1
interface Serial0
 ip address 23.0.2.6 255.255.255.248
 encapsulation ppp
ipv6 router ospf 222
12 Replies 12
I see two tunnels in your attachment. You need only one tunnel in this case.
Follow these steps.
1- Run OSPF on Router R0 and R1 and R2 and advertise IP address of your links and loopback1
2- Router R1 should ping both R2 link and loopback1.
3- Create a tunnel from R1 to R2 (only one Tunnel ) .
Configure the source and destination addresses. Source and destination addresses are 192.40.0.0 and 23.0.2.0
Configure an IPV6 address on Tunnel both sides.
4-You are able to ping the IPV6 address of R1 from R2 if your tunnel configuration is correct.
5- Configure OSPFv3 on R1 and R2 and advertise loopback 101 and 202.
Please share your config if you are not able to ping after the change.
Hope it helps,
Masoud
Hello
depends on what tunneliing IPv4 -IPv6 feature you are using
Can you post your confiig for these 3 rtrs please
res
paul
Kind Regards
Paul
I still cannot ping from either side
here's my configurations...Router 0 omitted...he's good to go.
i can only specify a source INTERFACE here in packet tracer for some reason
R2
interface Loopback2
no ip address
interface Tunnel1
no ip address
mtu 1476
tunnel source Serial0
tunnel destination 192.40.0.28
interface Serial0
router ospf 1
network 2.2.2.0 0.0.0.255 area 0
network 23.0.2.0 0.0.0.7 area 0
R1
interface Loopback1
no ip address
interface Tunnel1
no ip address
mtu 1476
tunnel destination 23.0.2.6
interface Serial0
router ospf 3
How about R0? Do you have OSPF on R0?
Can you ping 23.0.2.6 from R1?
can you ping 2.2.2.2 from R1?
Can you ping 2001:404:404:4::3 from R1?
hey Masoud
yes all IPv4 addresses are ping'able.
as far as OSPFv3 goes...i've tried configuring it on ONLY loop 101/202, then ONLY the Tunnel on BOTH sides, then BOTH
still nothing.
i even fixed my SOURCE/DESTINATION statements on both sides...still nothing.
R1...tunnel source Serial 0 tunnel destination 23.0.2.6
R2...tunnel source Serial 0 tunnel destination 192.40.0.28
everything looks good to me.
Share your final configurationin including R0, R1, R2 here so that I can test it on a simulator. and give the result back.
I finally got it to work.
I only used one Loopback each on R1 and R2.
I put IP4 and IP6 addresses on the same Loopback.
Plus, I added the tunnel mode ipv6ip statement.
One or both of those made it work.
Glad it worked. Check also my previous comment. I implemented you scenario in a simulator with your IPs. It worked. The result is attached to that comment. Please rate my comments if you are happy with.
Masoud
IPv6ip in unrelated, It may cause problem if MTU is not set properly.
I think your problem is OSPFV3. Please implement the configuration on my previous comment and share the result.
To check your tunnel: Ping the IP address of tunnel on the other side.
To check your routing table:  show ipv6 route.
R1
hostname R1
interface Loopback1
interface Tunnel1
interface Serial1/0
 encapsulation ppp
router ospf 3
R0
interface Serial0
 encapsulation ppp
interface Serial1
 encapsulation ppp
router ospf 1
R2
hostname R2
interface Loopback2
 no ip address
interface Tunnel1
 no ip address
interface Serial0
 encapsulation ppp
If you did not redistribute connected routes under ospfv3, add these commands
R1
R2
Please check this sample configuration. I checked it. It works. Topology is attached.
R2
 ip address 172.16.1.2 255.255.255.255
interface Loopback100
 ipv6 address 2003::1:1/124
 ipv6 enable
interface Tunnel0
ipv6 address 3FFE:B00:C18:1::2/127
 ipv6 ospf 1 area 0
 tunnel destination 2.2.2.1
interface FastEthernet0/0
 duplex half
router ospf 1
 network 172.16.1.2 0.0.0.0 area 0
ipv6 router ospf 100
R1
hostname R1
 ip address 172.16.1.1 255.255.255.255
 ip address 1.1.1.2 255.255.255.0
 duplex half
interface FastEthernet1/0
 duplex half
router ospf 1
R3
interface Loopback0
 ip address 172.16.1.3 255.255.255.255
 ipv6 address 2003::2:1/124
interface Tunnel0
 ipv6 address 3FFE:B00:C18:1::3/127
 ipv6 ospf 100 area 0
 tunnel source 2.2.2.1
 ip address 2.2.2.1 255.255.255.0
 duplex half
router ospf 10
 network 172.16.1.3 0.0.0.0 area 0
Masoud
