03-03-2013 05:47 AM - edited 03-04-2019 07:11 PM
Hello;
I am stumped here. I need to open ports 9080 and 5280 on my Cisco ASA 5505 firewall and despite doing everything I THINK I needed to do...when I run the utility to check from outside; it is NOT open....I utilize a website called http://www.yougetsignal.com/tools/open-ports/ (very good for these kinds of things) I have added the specific port(s) to my services so that I can CHOOSE them; added an ACE/ACL to; added incoming/outgoing rules to accomodate traffic to those ports....NOTHING.....what am I missing here?
03-03-2013 06:32 AM
What version of ios are you using?
HTH,
John
*** Please rate all useful posts ***
03-03-2013 08:23 AM
Version 8.2
03-03-2013 08:52 AM
Okay. It may be easier if you coiuld post what you have, but you'll need to map the ip/port that you want and then allow it through the ASA via an access-list. Say you wanted to allow port 80 into public address 1.1.1.1. You want to map the public address 1.1.1.1 to 192.168.1.1 on your lan. You'd do something like the following:
access-list OUTSIDE permit tcp any host 1.1.1.1 eq 80
static (inside, outside) tcp 1.1.1.1 80 192.168.1.1 80 netmask 255.255.255.255
access-group OUTSIDE in interface WAN
If you only want to map the address that the provider assigns you (a single address), you can do that with the interface command:
static (inside,outside) tcp interface 80 192.168.1.1 80 netmask 255.255.255.255
with an access-list:
access-list OUTSIDE permit tcp any interface eq 80
If this doesn't help, you'll need to post your config.
HTH,
John
03-03-2013 03:22 PM
Hello John;
Thanks for responding. It is helpful.
I guess it would be better if I more clearly illustrate what I am trying to do.
Basically; we have personal fax solution from our VOIP vendor which requires ports 9080 and 5280 open in order for the client based software to contact THEIR server. So I need my internal network 192.168.x.x to be able to communicate through my external interface 209.125.x.x on ports 9080 and 5280 and vice versa...now as this fax client can be installed on multiple machines inside the network; it makes since to allow those ports to communicate from any machine on the inside...right? Particularly since I don't have a specific IP or IPs that the external VOIP servers will be trying to come in FROM....
03-03-2013 04:44 PM
If your clients are initiating the connection, you can define it in a class map and then add that to the policy map and inspect it. Otherwise, you'll need to allow those ports back in. Post your config please...
HTH,
John
03-03-2013 05:32 PM
Okay...here is the most important part...
: Saved
ASA Version 8.2(5)
hostname ASA-Test
domain-name domain.local
enable password xxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxx encrypted
names
name 12.208.xx.xxx Test_Firewall
name 192.168.x.0 Test_Subnet
name 192.168.xxx.0 Test2_Subnet
name 192.168.x.0 Test_Remote_VPN_Network
name 50.197.xxx.xx FTP
name 192.168.xxx.xx TST-APP01
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
speed 100
duplex full
interface Ethernet0/6
switchport access vlan 3
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.xxx.x 255.255.255.0
interface Vlan2
description Outside Interface
nameif outside
security-level 0
ip address 50.197.xxx.xx 255.255.255.248
interface Vlan3
description Public (DMZ)
no forward interface Vlan1
nameif Public
security-level 50
ip address 192.168.21x.x 255.255.255.0
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
name-server 192.168.xxx.20
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service RemoteDesktop tcp
description Terminal Server port
port-object eq 3389
object-group network PUBLIC_outside
object-group network public_outside
object-group network DM_INLINE_NETWORK_1
network-object Test_Subnet 255.255.255.0
network-object Test_Remote_VPN_Network 255.255.255.0
object-group network DM_INLINE_NETWORK_3
object-group network DM_INLINE_NETWORK_2
network-object host xxx-APP01
network-object host FTP
object-group service Star2Star tcp
description Port used for Star2Star fax connections
port-object eq 9080
port-object eq 5280
access-list outside_1_cryptomap extended permit ip Test2_Subnet 255.255.255.0 Test_Subnet 255.255.255.0
access-list outside_1_cryptomap extended permit ip Test2_Subnet 255.255.255.0 Test_Remote_VPN_Network 255.255.255.0
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any interface outside object-group Star2Star
access-list inside_nat0_outbound extended permit ip Test2_Subnet 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list inside_nat0_outbound extended permit ip Test2_Subnet 255.255.255.0 Test_Remote_VPN_Network 255.255.255.0
access-list inside_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_3 Test2_Subnet 255.255.255.0
access-list outside_access_in extended permit tcp any host FTP eq ftp
access-list outside_access_in extended permit icmp any host FTP
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_2 eq ftp
access-list outside_access_in extended permit tcp any interface inside object-group Star2Star
access-list Public_access_in extended permit ip any any
access-list Public_access_in extended permit tcp any any object-group Star2Star
pager lines 24
logging enable
logging asdm informational : Saved
03-03-2013 06:02 PM
Can you post:
show run access-group
show run policy-map
show run class-map
HTH,
John
