ICMP on ASA 5520 (8.6) subinterface
w.janarthanan
                   Hi Geeks,
following is my setup on ASA
interface GigabitEthernet0/1.20
vlan 20
nameif ABC
security-level 100
ip address 10.20.100.1 255.255.255.0
interface GigabitEthernet0/1.30
vlan 30
nameif XYZ
security-level 100
ip address 10.20.200.1 255.255.255.0
SWITCH
1) all the clients are connected via L2 switch
2) gig 0/1 is trunk
3) allowed vlan 20 and 30
1) when i ping 10.20.200.1 from a client PC with 10.20.100.X ip i dont get the ping working
2) but when i ping a client inside 10.20.200.x from the same client PC with 10.20.100.X IP it works
3) its only the ASA subinterface that i cant ping from different VLAN clients.
can someone let me know the issue ?
i have enabled the following
icmp permit any ABC
icmp permit any XYZ
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
still no luck
16 Replies 16
johnnylingo
Level 5
Level 5
Since 10.20.100.1 and 10.20.200.1 are both the ASA itself, a ping from 10.20.100.X to 10.20.200.1 will use 10.20.100.1 as the source in the echo-reply, so that's why it's failing.
I know one work-around is to NAT.  But there are probably better ways.
hi johnnylingo,
thank you for your reply. the NAT is totally different in 8.6. do you knw how i can create a NAT to make this work ?
Usess Access List To Permit Traffic
access-list LANtoLAN extended permit ip any any
access-group LANtoLAN in interface ABC
access-groupLANtoLAN in interface XYZ
****Do Rate Helpful Post***
Jawad
hi Jawad Mukhtar
hi alreday have the below acl
access-group ABC_in in interface ABC
access-group XYZ_in in interface XYZ
access-list ABC_in extended permit icmp any any
access-list XYZ_in extended permit icmp any any
but still no luck.
Paste Your Running Config (leave Pass Blank)
Jawad
Hi Jawad Mukhtar,
no nameif
no security-level
no ip address
vlan 20
nameif IMIC
security-level 100
ip address 10.20.20.1 255.255.255.0
vlan 30
nameif AS
security-level 100
ip address 10.20.30.1 255.255.255.0
interface GigabitEthernet0/1.40
vlan 40
nameif SERVER
security-level 100
ip address 10.20.40.1 255.255.255.0
interface GigabitEthernet0/1.50
vlan 50
nameif AP
security-level 100
ip address 10.20.50.1 255.255.255.0
ftp mode passive
object network IMIC-NAT
subnet 10.20.20.0 255.255.255.0
description IMIC-NAT
object network AS
subnet 10.20.30.0 255.255.255.0
access-list im_access_in extended permit icmp any any
access-list im_access_in extended permit ip 10.20.20.0 255.255.255.0 any
access-list as_access_in extended permit icmp any any
access-list as_access_in extended permit ip 10.20.30.0 255.255.255.0 any
pager lines 24
logging asdm informational
mtu OUTSIDE 1500
mtu IMIC 1500
mtu AS 1500
mtu SERVER 1500
mtu AP 1500
mtu INTERNET 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any IMIC
icmp permit any AS
no asdm history enable
arp timeout 14400
nat (IMIC,AS) source static IMIC-NAT IMIC-NAT
nat (AS,IMIC) source static AS AS
access-group outside_access_in in interface OUTSIDE
access-group im_access_in in interface IMIC
access-group as_access_in in interface AS
access-group internet_access_in in interface INTERNET
route OUTSIDE 0.0.0.0 0.0.0.0 123.231.35.XX 1
route INTERNET 88.87.45.XX 255.255.255.255 172.16.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 10.20.20.11 255.255.255.255 IMIC
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh 10.20.20.11 255.255.255.255 IMIC
ssh timeout 60
console timeout 0
dhcpd address 10.20.20.20-10.20.20.254 IMIC
dhcpd dns 203.189.78.162 203.189.78.170 interface IMIC
dhcpd enable IMIC
dhcpd address 10.20.30.20-10.20.30.254 AS
dhcpd dns 203.189.78.162 203.189.78.170 interface AS
dhcpd enable AS
dhcpd address 10.20.50.20-10.20.50.254 AP
dhcpd dns 203.189.78.162 203.189.78.170 interface AP
dhcpd enable AP
<--- More --->
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
<--- More --->
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:eed0361ca8ad726ae58dacf6eb5568d2
: end
[OK]
Do Nat 0
NAT 0 means"Do Not Translate"
access-list NONATABC extended permit ip 10.20.100.0 255.255.255.0 10.20.200.0 255.255.255.0
access-list NONATXYZ extended permit ip 10.20.200.0 255.255.255.0 10.20.100.0 255.255.255.0
nat (ABC) 0 access-list NONATABC
nat (DEF) 0 access-list NONATDEF
Do Rate Helpful Posts
Jawad
Hi Jawad Mukhtar
Thank you for your reply , but i get the following error on the nat command
ERROR: This syntax of nat command has been deprecated.
Please refer to "help nat" command for more details.
As in your config you dont have Interface ABC and XYZ it was just an example.  U can do NOnat in above mentioned example.  Well you can add your Interface.
Like
IMIC
AS
Hope so u got my point
Jawad
I took a closer look by using a packet capture and found the ASA is just eating the flow.  For example, a ping from the inside network to outside IP address enters the inside interface and then just dies.  The ASA doesn't even send an unreachable packet back.  The packet trace tool says this:
RESULT - The packet is dropped.
Input Interface: Inside
Output Interface: NP Identity Ifc
I was thinking idenity NAT would change this behavior, but don't know if that's supported in 8.3 and above.
Here's a similar thread, and the consensus there seems to be there is no work-around for this behavior
https://learningnetwork.cisco.com/thread/4689
Jawad Mukhtar
I did the NAT as you said using my real interface name but the 8.3 CLI gives thats error. may be that kind of NAT command is no longer working.
johnnylingo,
i can ping host between inside and outside. its juz that i cant ping subinterface of inside interfacae.
Wat i got from you u want to ping host behind sub interfaces.
e.g
One host behind sub interface 1 can ping other other behind sub interface 2.
Jawad
Jawad Mukhtar,
you almost correct , but i can ping host/s cross wise within the subinterface.
E.g
Host A is in subinterface 0.1
Host B is in subinterface 0.2
I can not ping subinterface 0.2 (ip address) from host A . but i can ping any host IP address inside the 0.2 network from host A.
The ASA is a security device will not allow you to ping  a distant interface....
Jawad
