how enable net flow and how to find top-talker host.
ganesh881
Hello Team,
I have cisco switch 4500. Can any one tell me how enable net flow and how to find top-talker host.
Hello Ganesh,
Please find the below link to enable net flow in 4500 switch
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/20ew/configuration/guide/config/nfswitch.html
By the way what is your net flow collector?. Cisco,Solar winds,Manage Engine or a different one?.
Hi Ganesh, If you are using Cisco prime infrastructure as the netflow collector u need to use yep port 9991 . The top talkers can be found in the performance dashboard in the home tab. I believe " Manage Engine Netflow analyzer " is very good tool. Shabeeb
Jigar Dave
Level 3
Level 3
Genesh - you need to make sure couple things.
1. what netflow is configured in your environment?
2. 2055 port is used by solarwinds, make sure that port is open in your firewall from everywhere
3. on solarwinds you can see top talker by graphical presentation. apart to that, solarwinds netflow is giving you lot of other info. too. - their one month trial is also available, try that.
