How i can configure vpn at router 2801 ios version 12.4
griffith2009
I had the next configuration in pix 7.24, the peer is firewall nokia:
access-list vpnxxx extended permit ip host 1.1.1.1 host 10.10.10.7
access-list vpnxxx extended permit ip host 1.1.1.3 host 10.10.10.7
crypto ipsec transform-set tranxxx esp-3des esp-sha-hmac
crypto map xxxrules 10 match address vpnxxx
crypto map xxxrules 10 set peer 10.10.10.4
crypto map xxxrules 10 set transform-set tranxxx
crypto map xxxrules interface dmz
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp enable dmz
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group 10.10.10.4 ipsec-attributes
pre-shared-key *
How i can configure the same vpn at router 2801 ios version 12.4 with the same firewall nokia ?.
Thanks.
paolo bevilacqua
There are configuration examples on cco, use the search box top right of any page.
Jon Marshall
Or more specifically -
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
start at the above link. There are loads of examples for router configuration.
Jon
