how i can upgrade from 12.2(44)SE1 to 12.2(55)SE1
miada.murad
hi all
could you plz give me the instruction to upgrade switch 3750 from  12.2(44)SE1 to 12.2(55)SE1
waiting for reply
rsimoni
it is pretty easy
download the new image from CCO and put it in the flash: directory
change the boot statement to point to the new image
ie:
conft t
boot system flash:c3750-ipservicesk9-mz.122-55.SE1
wr
check if the boot statement has been correctly changed
show bootvar
reload the switch
The next link below is what you are looking for:
http://www.cisco.com/en/US/products/ps5855/products_tech_note09186a00801fc986.shtml
It has the detailed upgrade procedure including the Cisco  series 3700
Hope that helps!
Vasilis
