how i config to get sth similar
2005074F93956
The overallThe overalloutput of show ip routeoutput of show ip routeoutput of show ip routeoutput of show ip routeoutput of show ip routeoutput of show ip route
2 Accepted Solutions
i turn i forgot ip route and the network is wrong
i now juz left with dns
10 Replies 10
2005074F93956
Martin L
not sure what you asking, please clarify.
Regards, ML
**Please Rate All Helpful Responses **
i want to achieved the same result as Hq in the china
not sure if you guys working on the same class project or not, but they use static default routes and RIP as protocol at local LAN. they have shared files, analyze their configs.  see https://community.cisco.com/t5/network-management/unable-to-ping-across-the-cloud/m-p/4132539#M135699
Regards, ML
same class but different group .my connections is up but still cant ping it
i have achieved the same result as us in the china
same class but different group.my connection is up but still cant ping each other can help check my packet tracer. the china and france cant pint to the rest.
my the way ,i try called using nslookup to the dns server in my hq cant work
