How is my traffic being distributed/load-balanced here across two WAN links? No BGP metrics.
colossus1611
Hi All,
Just came across a new small customer site and can't understand how is the traffic being distributed/load-balanced across two WAN links on two separate WAN routers here. The configuration doesn't seem to have any BGP metrics to influence this. I am suspecting CEF load-balancing, but get no evidence of it (or possibly I don't know the right commands to look for it). The users are complaining of Voice traffic drop-outs and I have observed that this happens when the secondary link has high latency on it (something that I test with point to point pings with higher packet size). I would like to eliminate this secondary link as an issue here and hence firstly would like to know why am I seeing traffic on this secondary WAN link when primary is UP on first router all the time. The primary WAN link on RTR01 is 30mbps and secondary WAN link on RTR02 is 20mbps.
Here's some show outputs from both these routers:
RTR01#show int des
Interface Status Protocol Description
Gi0/0 up up Primary WAN link
Gi0/1 up up To LAN Distribution switch
Gi0/2 up up To LAN Distribution switch
RTR02#show int des
Gi0/0 up up Secondary WAN link
Gi0/1 up up To LAN Distribution Switch
Gi0/2 up up To LAN Distribution Switch
RTR02#show int gi0/0
Internet address is 10.252.0.42/30
MTU 1500 bytes, BW 20000 Kbit/sec, DLY 10 usec,
Last input 00:00:04, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3397863
Queueing strategy: Class-based queueing
Output queue: 0/1000/3397834 (size/max total/drops)
1 minute input rate 63000 bits/sec, 20 packets/sec
1 minute output rate 35000 bits/sec, 12 packets/sec
RTR01#show int gi0/0
Internet address is 10.252.0.54/30
MTU 1500 bytes, BW 30000 Kbit/sec, DLY 100 usec,
Full Duplex, 100Mbps, media type is RJ45
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1054415
Output queue: 0/1000/1054257 (size/max total/drops)
1 minute input rate 72000 bits/sec, 17 packets/sec
1 minute output rate 94000 bits/sec, 32 packets/sec
1563558175 packets input, 963665363 bytes, 0 no buffer
Received 5165957 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
2763543459 packets output, 3923617842 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
5165956 unknown protocol drops
RTR01#show run | s bgp
router bgp 12345
bgp log-neighbor-changes
redistribute connected
redistribute ospf 100 metric 10 route-map ospf-to-bgp
neighbor 10.252.0.53 remote-as 6789
neighbor 10.252.0.53 update-source GigabitEthernet0/0
neighbor 10.252.0.53 timers 8 24
neighbor 10.252.0.53 soft-reconfiguration inbound
neighbor 10.252.0.53 route-map bgp-in in
neighbor 172.31.232.3 remote-as 12345
neighbor 172.31.232.3 update-source Port-channel1.10
neighbor 172.31.232.3 soft-reconfiguration inbound
route-map bgp-in deny 10
match ip address prefix-list ospf-in
route-map bgp-in permit 20
route-map ospf-to-bgp permit 10
set origin igp
snmp-server enable traps bgp
RTR01#show ip prefix-list ospf-in
ip prefix-list ospf-in: 1 entries
seq 10 permit 172.31.232.0/22 le 32
RTR01#show route-map bgp-in
route-map bgp-in, deny, sequence 10
Match clauses:
ip address prefix-lists: ospf-in
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map bgp-in, permit, sequence 20
Match clauses:
Set clauses:
RTR02#show run | s bgp
router bgp 12345
neighbor 10.252.0.41 remote-as 6789
neighbor 10.252.0.41 update-source GigabitEthernet0/0
neighbor 10.252.0.41 soft-reconfiguration inbound
neighbor 10.252.0.41 route-map bgp-in in
neighbor 172.31.232.2 remote-as 12345
neighbor 172.31.232.2 update-source Port-channel2.10
neighbor 172.31.232.2 soft-reconfiguration inbound
set origin igp
RTR02#show route-map bgp-in
Match clauses:
Set clauses:
Match clauses:
Set clauses:
RTR02#show ip prefix-list ospf-in
Hello @colossus1611 ,
you can have per flow load balancing in the upstream direction (to the internet) if the distribution switches participate in OSPF and they see two default route in OSPF injected by R1 and R2.
This would not be true if they would use a default static route pointing to the HSRP VIP in po1.10 ( this may be a relic the trace of an old configuration).
For traffic coming from the internet to your prefixes how traffic come back depend on the topology within ISP AS 6789. Traffic can come back via a single path if both PE routers have the same IGP cost from core but one of them has a lower BGP RID.
There is little you can do about this just to ask to the ISP to implement multpath in order to have both WAN links used in downstream.
To check how many prefixes you are learning you can use
show ip bgp summary
the righmost column provides the number of prefixes received
Hope to help
Giuseppe
7 Replies 7
post  a schematic drawing of the entire topology, as well as the full running configurations of the two routers (sh run).
Hi Georg,
Please find attached the show run output for both WAN routers (Edit - let me know pls if the attachments aren't visible, as I can't see it for some reason after I posted).
The topology is as below:
Posting truncated config text for RTR01 and RTR02 as attachments aren't visible  (atleast to me).
hostname RTR01
no ip source-route
ip cef
no ipv6 cef
track 1 interface GigabitEthernet0/0 line-protocol
class-map match-any MEDIUM-PRIORITY
match access-group name SAP
match protocol ldap
match protocol ipsec
match ip dscp cs2
match ip dscp af21
class-map match-any WAN-VOICE
match ip dscp ef
class-map match-any WAN-VIDEO
match ip dscp af41
class-map match-any HIGH-PRIORITY
match protocol telnet
match protocol snmp
match protocol dns
match protocol rtcp
match protocol ssh
match ip dscp cs3
match ip dscp af31
class-map match-any WAN-MED
match ip dscp af21
class-map match-any VIDEO
match ip dscp cs4
match ip dscp af41
class-map match-any VOICE
match ip dscp ef
class-map match-any WAN-HIGH
match ip dscp af31
policy-map WAN-QOS
class WAN-VOICE
priority percent 30
class WAN-HIGH
bandwidth percent 10
class WAN-MED
class WAN-VIDEO
bandwidth percent 40
class class-default
fair-queue
random-detect dscp-based
set dscp default
policy-map WAN-SHAPING
class class-default
shape average 30000000
service-policy WAN-QOS
policy-map IN-QOS
class VOICE
set dscp ef
class HIGH-PRIORITY
set dscp af31
class MEDIUM-PRIORITY
set dscp af21
class VIDEO
set dscp af41
interface Loopback0
ip address 172.31.1.21 255.255.255.255
interface Port-channel1
description (M)SWD01:Po1
no ip address
no ip proxy-arp
load-interval 60
service-policy input IN-QOS
hold-queue 150 in
interface Port-channel1.10
encapsulation dot1Q 10
ip address 172.31.232.2 255.255.255.128
no ip proxy-arp
standby 1 ip 172.31.232.1
standby 1 priority 110
standby 1 preempt
standby 1 track 1 decrement 20
ip ospf 100 area 0.0.0.0
description Primary WAN link
bandwidth 30000
ip address 10.252.0.54 255.255.255.252
no ip proxy-arp
ip flow ingress
ip flow egress
load-interval 60
duplex full
speed 100
no cdp enable
service-policy output WAN-SHAPING
interface GigabitEthernet0/1
description (M)SWD01:Gi1/0/1
no ip address
no ip proxy-arp
duplex auto
speed auto
channel-group 1
interface GigabitEthernet0/2
description (M)SWD01:Gi2/0/1
no ip address
no ip proxy-arp
duplex auto
speed auto
channel-group 1
router ospf 100
default-information originate
distribute-list prefix ospf-in in
router bgp 12345
ip flow-top-talkers
top 20
sort-by bytes
cache-timeout 900000
ip prefix-list ospf-in seq 10 permit 172.31.232.0/22 le 32
ip sla 21
udp-jitter 172.31.1.251 20000 codec g711alaw
ip sla schedule 21 life forever start-time now
ip sla 22
icmp-echo 172.31.1.251
ip sla schedule 22 life forever start-time now
ip sla responder
set origin igp
end
hostname RTR02
no ip source-route
ip cef
no ipv6 cef
redundancy
match protocol ldap
match ip dscp cs2
match ip dscp af21
match ip dscp ef
match ip dscp af41
match protocol snmp
match protocol dns
match protocol rtcp
match protocol ssh
match ip dscp cs3
match ip dscp af31
match ip dscp af21
match ip dscp cs4
match ip dscp af41
match ip dscp ef
match ip dscp af31
policy-map WAN-QOS
class WAN-VOICE
priority percent 30
class WAN-HIGH
class WAN-MED
class WAN-VIDEO
class class-default
fair-queue
set dscp default
class class-default
shape average 20000000
policy-map IN-QOS
class VOICE
set dscp ef
class HIGH-PRIORITY
set dscp af31
set dscp af21
class VIDEO
set dscp af41
interface Loopback0
ip address 172.31.1.24 255.255.255.255
interface Port-channel2
description (M)SWD01:Po2
no ip address
no ip proxy-arp
load-interval 60
hold-queue 150 in
interface Port-channel2.10
ip address 172.31.232.3 255.255.255.128
no ip proxy-arp
standby 1 preempt
description Secondary WAN link
bandwidth 20000
ip address 10.252.0.42 255.255.255.252
no ip proxy-arp
ip flow ingress
ip flow egress
load-interval 60
duplex auto
speed auto
no cdp enable
description (M)SWD01:Gi1/0/2
no ip address
no ip proxy-arp
duplex auto
speed auto
channel-group 2
description (M)SWD01:Gi2/0/2
no ip address
no ip proxy-arp
duplex auto
speed auto
channel-group 2
router ospf 100
router bgp 12345
ip flow-top-talkers
top 20
sort-by bytes
ip access-list standard ALL-ROUTES-OUT-v01
permit any
ip access-list extended SAP
permit ip any 10.38.64.0 0.0.1.255
ip sla 21
ip sla 22
ip sla responder
logging source-interface Loopback0
set origin igp
end
show ip bgp summary
Hope to help
Giuseppe
Hi Giuseppe,
Yes that's absolutely right. The distribution swtich is participating in OSPF process and has two equal cost routes towards RTR01 and RTR02.
SWD01#
O*E2 0.0.0.0/0 [110/1] via 172.31.232.3, 6d14h, Vlan10
[110/1] via 172.31.232.2, 6d14h, Vlan10
As for the return routes, I wasn't sure if there's anything that the rotuer has on it's configruation to do cef load balancing (I couldnt' find any), so thanks for confirming that this is definitely being managed by ISP and not us. The second ISP link is showing BPG drops and output packets drops, for which they aren't taking responsibility.
Leonid Voronkin
Does AS6789 advertise to you only default through both uplinks? Or maybe full-view?
Can you show show ip bgp from both routers? In case of full-view don't show all output. Just tell about it :-)
Plus show ip bgp neighbors 10.252.0.53 advertised-routes from RTR01 and show ip bgp neighbors 10.252.0.41 advertised-routes from RTR02
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
Hi Leonid,
Yes I am getting more than default routes from AS6789.
Here's the routes being advertised, but nothing fancy there. I think as Giuseppe confirmed this is definitely being load balanced at distribution switch for outgoing routes. It's the incoming traffic that I was wondering about and how it is load balanced as I couldn't see any traces of BGP or CEF load balancing configuration on routers. Seems like ISP might be controlling it inbound.
RTR01#show ip bgp neighbors 10.252.0.53 advertised-routes
Network Next Hop Metric LocPrf Weight Path
*>i 10.252.0.40/30 172.31.232.3 0 100 0 ?
*> 10.252.0.52/30 0.0.0.0 0 32768 ?
*>i 10.252.0.56/30 10.252.0.41 0 100 0 6789 i
*> 172.31.1.21/32 0.0.0.0 0 32768 ?
*>i 172.31.1.24/32 172.31.232.3 0 100 0 ?
*> 172.31.232.0/25 0.0.0.0 0 32768 ?
*> 172.31.232.128/25
172.31.232.5 10 32768 i
*> 172.31.233.0/24 172.31.232.5 10 32768 i
*> 172.31.234.0/24 172.31.232.5 10 32768 i
*> 172.31.235.0/24 172.31.232.5 10 32768 i
RTR02#show ip bgp neighbors 10.252.0.41 advertised-routes
*>i 10.252.0.8/30 10.252.0.53 0 100 0 6789 i
*> 10.252.0.40/30 0.0.0.0 0 32768 ?
*>i 10.252.0.52/30 172.31.232.2 0 100 0 ?
*>i 10.252.0.76/30 10.252.0.53 0 100 0 6789 i
*>i 10.252.0.112/30 10.252.0.53 0 100 0 6789 i
*>i 172.31.1.21/32 172.31.232.2 0 100 0 ?
*>i 172.31.1.23/32 10.252.0.53 0 100 0 6789 i
*> 172.31.1.24/32 0.0.0.0 0 32768 ?
*>i 172.31.245.0/25 10.252.0.53 0 100 0 6789 i
*>i 172.31.245.128/25
