How many BGP neighbor specific distance commands can be configured?
sal-mahmood1
How many BGP neighbor specific distance commands can be configured? I am using Cat6500 with IOS.
Credits go to Julio. I was just trying to elaborate and clarify...
10 Replies 10
Julio E. Moisa
Could you please provide more details about the question?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I have one cat6500 bgp-router with 4 ebgp neighbors and admin-distance modification (for external-routes) command to make this router as backup path as below:
router bgp 100
neighbor 1.1.1.1 remote-as 200
neighbor 2.2.2.2 remote-as 300
neighbor 3.3..3.3 remote-as 400
neighbor 4.4.4.4 remote-as 500
address-family ipv4
distance bgp 200 200 200
This distance command applies to all neighbors. Now I want to change this router to be the primary path for neighbor 2.2.2.2. So I am thinking of deleting this command and use neighbor specific distance commands for other neighbors (excluding 2.2.2.2).
You can also use BGP attributes to create backup, now you could use the following command before to delete the distance statement
router bgp 100
bgp log-neighbor-changes
distance <administrative distance> <source IP it can be the neighbor 2.2.2.2> <wildcard should be 0.0.0.0> <ACL to match, example 1>
Sintaxis
distance <administrative distance 1-255> <source IP> <wildcard> <ACL>
example:
access-list 7 permit 192.168.1.0 0.0.0.255
access-list 7 permit host 172.16.1.77
distance 19 2.2.2.2 0.0.0.0 7
So if you are receiving the networks includedo into the ACL 7 and advertised by the source address 2.2.2.2  it will apply the administrative distance of 19 for the networks into the ACL 7.
You could try that.
So the neighbor-specific distance statement will have higher priority right?
You mean when you have both:
and
distance 15 2.2.2.2 0.0.0.0
in your BGP configuration ? Yes, distance 15 2.2.2.2 0.0.0.0 will take precedence...
Thanks a lot for your help. I will try it in few days.
in addition to Julio's post (hopefully I am not saying the exact same thing), and that is I think what you are trying to do, you can simply set the distance for neighbor 2.2.2.2 to something lower like the default (20 for EBGP):
You don''t need to set the distance for the other neighbors, since the default is higher than 15.
You are welcome, please keep us posted.
