How many BGP peers on 7204NPG1?
I am using BGP4 on a private internet, I have to establish a 400 peers on a CISCO router (7k2 NPG1). I would like to know if that are afordable figures I just not?.
Wilson Samuel
Level 7
Level 7
To be honest with you, NPG-1 can handle 400 peers pretty easily provided there not many Attribs in use and if you could you use the BGP Peer Group.
You may follow the below link for further information:
http://cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093fb7.shtml
http://cisco.com/en/US/docs/ios/12_0/np1/configuration/guide/1cbgp.html
HTH,
Please rate if it helps
Kind Regards,
Wilson Samuel
