HOW MANY DAILER INTERFACES WE CAN CREAT ON CISCO ROUTERS
Sandeepka
Is there any limitation on number of dialer interfaces on cisco routers, If yes, then on what parameters this dependancy is created means creating large num of dialer interfaces (1000) affect the router performance by consuming router resources.
Richard Burts
Sandeep
You posted essentially the same question on Jun 17, 2010 4:47 AM and I posted a response. So I am puzzled why you are posting the same question again in the same forum?
Rick
Rick
Because some people are desperate to get an answer.  Any answer.
Don't know why he or they didn't contact a Cisco SE or the authorized Cisco reseller.
