WAN traffic routing
Praveen AR
we have 4507 as core switch,3560 as edge switch .Edge switches are connected to core switch using ether channel.Following are the data vlans in the network
Vlan 301 - 192.168.32.0/24
Vlan 302 - 192.168.33.0/24
Vlan 303 - 192.168.34.0/24
Vlan 304 - 192.168.35.0/24
Vlan 305 - 192.168.36.0/24
Vlan 313 - 192.168.44.0/24
Vlan 315 -  192.168.45.0/24
Vlan 316 - 192.168.46.0/24
Vlan 317 - 192.168.47.0/24
Vlan 318 - 192.168.48.0/24
Vlan 319 - 192.168.49.0/24
vlan 320 - 192.168.50.0/24
Vlan 321 - 192.168.51.0/24
Vlan 322 - 192.168.52.0/24
Vlan 323 - 192.168.53.0/24
Vlan 324 - 192.168.54.0/24
vlan 325 - 192.168.55.0/24
our client is planning to take 5 separate PPoE broadband  internet connection for this project.The client want to route traffic from
Vlan 301 to port connecting  first internet connection
vlan 302  to port  connecting  second internet connection
vllan 303 to port   connecting  Third internet connection
vlan 304 to  connecting  Fourth internet connection
and rest of the vlans to fifth internet
I want to know is it possible to route traffic from particular vlan to  specific  ethernet port connecting to internet.if it is possible which router can be used for this solution and how traffic  can be routed.
please advise me
12 Replies 12
Jerry Ye
Assuming the SUP on the 4500 is able to do L3 and the NAT are done by seperate devices (Catalyst 4500 and 3500 doesn't support NAT), then you should be able to do PBR.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/52sg/configuration/guide/pbroute.html
HTH,
jerry
If we are doing policy based routing ,the internet  connection should be terminated directly to core switch 4507.In this case which device i can use for NAT ing function
This is the problem where the 4507 cannot do NAT. You might want to terminate the internet connection on seperate routers (not switches, the only switch that support NAT is the Catalyst 6500).
jerry
Is it possible to terminate all internet connection in a single router connecting to core switch and do PBR and NAT on this router.
If i am using separate five routers,Which routers i can use .
Can i use cisco small  business routers.
Depends on the bandwidth of your requirements.
Each broadband internet  connection speed is 32 Mbps.Does smal business routers is efficient to do dynamic  NAT ing
which router should be  used in this situation if i am using separate routers for each internet connection.
Is it possible to do the solution with single route instead of multiple routers.
I doubt if any SB router can do 32 mb EACH.
It means if i have five 32 mbps PPoE broadband  internet connection ,I need five routers to impliment this solution.
Which  cisco router is prefered for this solution.
Praveen AR
Does anyone has solution to this scenario
I'd be looking at a 1841 router.  The router is rated at 75Mbps (half-duplex, un-encrypted).
Router Performance
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Don't forget to rate useful posts.  Thanks.
Hi Leo,
The OP needs to terminate 5 PPPoE in one router.
jerry
