How many IPSEC crypto map can be binded in one Cisco router
sandipani
Hi:
Can any one tell me , how many crypto map I can bind in one serial ineterface of Cisco router for multiple site to site VPN.
regards
Sandipani C.
Richard Burts
Sandipani
In one serial interface you can bind only one crypto map. If you have multiple sites one crypto map works ok when you create multiple instances within the crypto map which might look like this:
crypto map sample_map 10 ipsec-isakmp
set peer
set transform-set
set pfs
match address
crypto map sample_map 20 ipsec-isakmp
set peer
set transform-set
set pfs
match address
crypto map sample_map 30 ipsec-isakmp
set peer
set transform-set
set pfs
match address
The router can have multiple crypto maps, but each map would go on a different interface.
Rick
Rick
