How many T1 interfaces supported on a 1841 Router?
scott.hale
I have a vendor telling one of our people that the 1841 router will only support 1 T1 WAN link. I'm pretty sure that is incorrect, but I thought I'd research before I start calling them out.
I know there are two slots on the 1841 router, so my assumption is that I can use two 1DSU-T1 V2 modules and support two separate T1 WAN connections. Any reason that I can't do this? I can find no documentation explicitly saying that I can't.
Thanks in advance,
Scott
paolo bevilacqua
Yes, you can also use vwic-2mft-t1 and have both circuits into a single slot.
