how PAT not working on cisco router?
Herman2018
Level 3
Level 3
hi, I am trying to config PAT on the router SAC01, configured the nat as shown below. IP address translation happened when I ping the external server ip with the source IP 10.10.1.1- interface g0/0 of SAC01, but when ping from VPC, then NAT is not working. the source ip doesn't translated. Can someone please help advise why it doesn't work? I test on eve-ng, Thanks in advance!
Config on SAC01
int g0/0
ip add 10.10.1.1 255.255.255.0
ip nat inside
int g0/1
ip addr 10.20.1.1 255.255.255.0
ip nat outside
ip nat inside source list 1 interface GigabitEthernet0/1 overload
access-list 1 permit any
config on VPC
IP Address: 10. 10.1.10 255.255.255.0 ,gateway 10.10.1.1
can ping the gateway IP ( the ip address of SAC01 interface g0/0)
7 Replies 7
M02@rt37
Hello @Herman2018
Enable debug to check NAT in action:
debug ip nat
Best regards
How router config as CoreSW??
MHM
Thanks M02@rt37  for your response, on the core switch, just configured the ports G0/0 and G0/2 to the same vlan (access vlan), I ca@n ping 10.10.1.1(SAC01 interface G0/0) from VPC.
Thanks @MHM Cisco World for your advice, I have turn on debug , there is no output and nat table is empty. But when I ping to external server with the source IP 10.10.1.1 (local interface ), then can see the source IP is translated to external interface IP. I also turned on debug ip icmp on the server, the source IP is still VPC when ping from VPC.
thanks @Scott Leport for your advice, I think the routing should be correct. For VPC, the gateway is 10.10.1.1 (SAC01 interface G0/0), and there is static route for the outbound traffics on SAC01.
Please
debug ip nat
Best regards
I ask about coreSW if it L3 device then traffic not reach NATing device
MHM
Scott Leport
Level 7
Level 7
I just labbed up something very similar in EVE-NG and NAT translation works as expected for me. Assuming static routing here, make sure that your routing end-to-end is good.
Hello
try the following:
SAC01
conf t
no access-list 1
access-list 1 permit 10.10.1.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 gig0/1 10.20.1.x <next hop interface ip>
Kind Regards
Paul
