How route traffic based in "iP destination" using isis
ingridrp
Good, Best Regards,
I appeal to you to help me to my next question
I have 3 Cisco 7200 router, IOS 12.2 all interconnected by links pto pto.
Router 1 to Router 2
Router 1 on router 3
Router 2 to router 1
Router 2 to router 3
Router 3 Router 1
Router 3 Router 2
I need that a CIDR of addressed  /24  always take router -- "Route 3 to Router 1" and return the same,l based only if your destination address is X.X.X.X
isis used as routing protocol
Do I use PBR?
Ingrid
John Blakley
If your destination address is going a different direction than your route in the routing table, you'll need to configure pbr. For example, if you have a host at 1.1.1.1 and you want it go to R2 - R1 from R3, but you have 1.1.1.0/24 on R3 that points to R1, you would need pbr to force the traffic to R2 first and override the routing table.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
Thanks!
