Using NAT through a Tunnel Interface on a 1921 router
ngthen
My company just acquired another organization and they have the same subnet as another recent acquisition.  I have a tunnel interface configured on their 1921 router (running 15.2) to my firewall and I can ping through to the tunnel's IP from HQ and vice versa.  The problem is that I cannot reach the LAN since there is another VPN tunnel at HQ using 192.168.1.0/24.  Is there a way on a 1921 to apply a NAT statement to essentially masquerade the subnet so at HQ it looks like 172.16.131.0/24 instead of 192.168.1.0/24?  I would need to do this on the router since my Palo Alto firewall cannot NAT the destination coming into HQ.  At the same time the router is being used for Internet access with a NAT pool.  I have attached the config below if anyone has any ideas.
hostname GSDN-RTR1
boot-start-marker
boot-end-marker
enable secret 4 ************
no aaa new-model
ip cef
ip name-server 207.230.75.50
ip name-server 207.230.75.34
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX175080LL
redundancy
lldp run
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 2
lifetime 28800
crypto isakmp key ************ address 198.199.129.150
crypto ipsec transform-set Corp-TS esp-aes 256 esp-sha-hmac
mode tunnel
crypto ipsec profile Corp-IPSec
set transform-set Corp-TS
interface Tunnel0
ip address 172.16.95.130 255.255.255.252
tunnel source 209.16.244.14
tunnel mode ipsec ipv4
tunnel destination 198.199.129.150
tunnel protection ipsec profile Corp-IPSec
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip nat inside
ip virtual-reassembly in
duplex full
speed 10
rj45-auto-detect-polarity disable
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
service-module t1 timeslots 1-24
cdp enable
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
description Acquisition WAN
ip address 209.16.244.14 255.255.255.248 secondary
ip address 10.22.5.74 255.255.255.252
ip access-group 107 in
ip nat outside
frame-relay interface-dlci 100 IETF
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool nat 209.16.244.9 209.16.244.9 netmask 255.255.255.248
ip nat inside source list 1 pool nat overload
ip nat inside source static 192.168.1.100 209.16.244.10
ip nat inside source static 192.168.1.101 209.16.244.11
ip route 0.0.0.0 0.0.0.0 10.22.5.73
ip route 10.50.1.0 255.255.255.0 172.16.95.129
ip route 172.16.0.0 255.255.240.0 172.16.95.129
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 107 permit tcp any any established
access-list 107 permit tcp host 97.73.172.178 host 209.16.244.10
access-list 107 permit tcp host 97.73.172.178 host 209.16.244.11
access-list 107 permit tcp host 98.83.70.197 host 209.16.244.11
access-list 107 permit tcp host 98.83.70.197 host 209.16.244.10
access-list 107 permit tcp host 71.8.40.69 host 209.16.244.10
access-list 107 deny   ip any host 209.16.244.10
access-list 107 deny   ip any host 209.16.244.11
access-list 107 permit ip any any
snmp-server community ITC-Public RO
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
exec-timeout 15 0
password 7 ************
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
line vty 5 15
login
transport input all
scheduler allocate 20000 1000
end
Found this on the support forums
https://supportforums.cisco.com/docs/DOC-5061
similar concept to what you trying to accomplish
CCNP, CCIP, CCDP, CCNA: Security/Wireless
Blog: http://ccie-or-null.net/
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
5 Replies 5
SOcchiogrosso
Level 4
Level 4
There should not be any reason you can't mark ip NAT outside on the GRE interface towards this location and update the NAT statements accordingly. I would also update the your NAT statements and use route maps to match the interface
Do you have an example of how to set it up?
Just what I was looking for.  I didn't see an option anywhere to NAT the entire subnet specifically with a route map.  Any thoughts on if this one can be done?
SOcchiogrosso
Level 4
Level 4
You'd have to do NAT overload / pat or do static NAT for individual IPs
