How the BGP AS number is traceroute interpeated
csco10851021
I have following senario.
R1(AS2914)--------------R2(AS5689)------------R3(AS5689)----------R4(AS5689)----------R5(AS5689)
R2, R3 and R4 are in same BGP AS.R3 is RR.
If i do the trace from R2 to R4 loopback,Why is the AS number 2914 is shown ?...i think it should show AS 5689.
R2#traceroute 192.168.161.7
Tracing the route to 192.168.161.7
  1 172.20.0.53 [AS 2914] [MPLS: Label 359 Exp 0] 20 msec
  2 172.20.0.5 [AS 2914] [MPLS: Label 20 Exp 0] 0 msec
  3 172.16.21.46 [AS 2914] 28 msec *  36 msec
/Ganpat
Reza Sharifi
See your other post
Hi Reza,
Which post you are refering to?
/Ganpat
can you run
sh ip bgp  172.20.0.53
sh ip bgp  172.16.21.46
on your router R2?
I believe the best BGP path will be showing a prefix coming from AS 2914  for those addresses.
HTH,
Milan
