How the order of PATHS in bgp table is governed ? is it on first come basis or based on preference ??
umeshpathrwal10
for example in below output , path 3  will prefer path 2  but is listed as path 3 .... Any  views here ......
sh bgp vrf ONE97-H2 172.21.214.161
Mon Jan 28 05:30:17.777 IST
BGP routing table entry for 172.21.214.0/24, Route Distinguisher: 9730:22790
Versions:
  Process           bRIB/RIB  SendTblVer
  Speaker         2971637905  2971637905
Last Modified: Jul 18 01:05:27.680 for 27w5d
Paths: (3 available, best #1)
  Advertised to CE peers (in unique update groups):
    172.37.141.98
  Path #1: Received by speaker 0
    172.37.141.98
  64520
    172.37.141.214 from 172.37.141.214 (172.37.138.54)
      Origin incomplete, metric 0, localpref 100, valid, external, best, group-best, import-candidate, imported
      Received Path ID 0, Local Path ID 0, version 2971637905
      Extended community: RT:9730:22774
      Source AFI: VPNv4 Unicast, Source VRF: ONE97-S4, Source Route Distinguisher: 9730:22990
  Path #2: Received by speaker 0
  Not advertised to any peer
  64520 64520 64520
x.x.37.49 (metric 322) from x.x..37.10 (x.x..37.49)
      Received Label 27022
      Origin incomplete, metric 0, localpref 100, valid, internal, imported
      Received Path ID 0, Local Path ID 0, version 0
      Originator: x.x.37.49, Cluster list: 0.0.0.22, 0.0.38.2, 0.0.0.80
      Source AFI: VPNv4 Unicast, Source VRF: default, Source Route Distinguisher: 9730:22774
  Path #3: Received by speaker 0
  64520 64520
    x.x.x.x.220 (metric 2) from x.x.x.10 (x.x.x..220)
      Received Label 4579
      Originator: x.x.x..220, Cluster list: 0.0.0.22
      Source AFI: VPNv4 Unicast, Source VRF: default, Source Route Distinguisher: 9730:22775
Francesco Molino
Just to make sure i answer your question, you're asking how that paths are ordered in your show ip bgp output?
If so, it's based on the order the router learned the routes.
The top one is the newest learned route and the bottom one is the oldest.
Then when you read this output, you can know which one was the newest to the oldest (from top to down).
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
