How to activate 3 BRIs to one dialer1 ?
cindylee27
Hi Experts,
IF i have 3 BRI interfaces, I would like to activate 1st BRI first and only will activate the 2nd BRI when the data across is more than 128kbps, what is the configuration i can do that?
I have 2 dialers but only want to apply it to the dialer1.
Thanks in advanced.
imranimemon
Creat dialer-group for each bri interface and assign it to dialer interface for creating group of 3 BRI.
and for firing channels above 128kbps bandwidth configure dialer load-threshold 128 either.
Imran
Hi Imran,
Do you have a simple example configuration on this?
Thanks again..
