how to activate Cisco Broadband license on ASR1001
kashalo84
Beginner
Beginner
Am trying to activate our broadband license on Cisco ASR 1001 with asr1001-universal.03.07.00.S.152-4.S.bin but i didn't find how to activate it  and i have serached all internet for hints but no luck would please help to activate the license.
Thanks in advance
5 Replies 5
Bilal Nawaz
Engager
Engager
http://www.cisco.com/en/US/docs/ios-xml/ios/csa/configuration/xe-3s/csa-cfg-sw-activation.html
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Dear Bilal
thanks for your replay but i have installed the license and when i enter the show license command i got the following status
Router#sh license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
adventerprise                      yes          yes              no                no          yes
advipservices                      yes          yes              no               yes          yes
ipbase                                no           no                no               no             no
avc                                     no           no                no               no             no
broadband                           no           no                no               no             no
broadband_4k                      no           no                no               no             no
and as you can the broadband license is installed but is not enabled and also when i enter the command show license
Router#sh license
Index 1 Feature: adventerprise
        Period left: 8  weeks 3  days
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA accepted
        License Count: Non-Counted
        License Priority: Low
Index 2 Feature: advipservices
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: ipbase
Index 4 Feature: avc
Index 5 Feature: broadband
Index 6 Feature: broadband_4k
        License Count: 1/0/0  (Active/In-use/Violation)
and also it show that the license is active but not in use and i wonder how can i enable it.
Thanks again
Did you figure this out? I'm in exactly the same boat.
Ironically we have the same question now again 4 years later, have you solved this ?
We have an client that is using its box as a L2TP server with over 2000 sessions but the feature will not show "In Use"
StoreIndex: 3  Feature: broadband_4k                      Version: 1.0
License Count: 4/0/0  (Active/In-use/Violation)
StoreIndex: 4  Feature: broadband                         Version: 1.0
Thanks in advance,
Ironically, four years later I have exactly the same problem: broadband_4k Active/Not-in-use.
Please help
Recognize Your Peers
