How to add Public Static Address Block
jeremigio
So i have a main public ip address to use for our internet connection which is in gi0/0/0 100.100.100.154 255.255.255.252 and my lan interface is gi0/0/1 192.168.1.1 255.255.255.0. and now we bought a block of 5 ip address from our ISP. which is 100.100.101.32/29 and on my interface gi0/0/2 is 100.100.101.33 255.255.255.248 the problem is when my computer is directly connected to the gi0/0/2 i cannot ping my gateway which is .33 and my computer ip is the next usable ip with is 100.100.101.34
and supposed to be the .34 will be directly connected to the internet.
this is the current configuration of my interface, static route and access list:
interface GigabitEthernet0/0/0
description Internet
ip address 100.100.100.154 255.255.255.252
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
description SG500
ip nat inside
negotiation auto
interface GigabitEthernet0/0/2
description Static IP
ip address 100.100.101.33 255.255.255.248
negotiation auto
ip route 0.0.0.0 0.0.0.0 100.100.100.153
ip route 192.168.2.0 255.255.255.0 192.168.1.2
ip route 192.168.3.0 255.255.255.0 192.168.1.2
ip route 192.168.4.0 255.255.255.0 192.168.1.2
ip route 192.168.5.0 255.255.255.0 192.168.1.2
ip route 192.168.10.0 255.255.255.0 192.168.1.2
ip route 192.168.11.0 255.255.255.0 192.168.1.2
ip route 200.0.0.0 255.255.255.0 192.168.1.2
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.5.0 0.0.0.255
access-list 1 permit 192.168.11.0 0.0.0.255
access-list 1 permit 172.168.0.0 0.0.0.255
access-list 1 permit 200.0.0.0 0.0.0.255
access-list 112 permit ip any any
what do i need to add some configuration to make this work?
thank you
6 Replies 6
chrihussey
Looks pretty cut and dry.
Did the router interface show up/up?
Double check the mask you gave the laptop.
Did the router show an ARP entry?
Does the laptop have a firewall / security policy denying ICMP?
These are good questions to investigate the issue, especially the question about whether there is an arp entry. In addition it would help if we could see output from the PC for ipconf and for arp -a
Rick
Rick
my ipconfig on laptop:
ip address: 100.100.101.34
subnet mask: 255.255.255.248
gateway: 100.100.101.33
and this is the arp related to the subnet and cannot see the ip of my laptop on it:
Internet 100.100.101.33 - 002c.c853.6f82 ARPA GigabitEthernet0/0/2
Internet 100.100.101.36 0 Incomplete ARPA
Yes it is up/up and i can ping 101.33 from outside my network (different isp)
yes i doubled check. the subnet mask is 255.255.255.248, my ip address is 100.100.101.34 and gateway is 100.100.101.33
no i didn't see 101.34 in my arp entry.
i tried disabling my firewall and still the same result.
the problem was the startech sfp module is not compatible with my cisco 4331 router. lol
Ahh. Thanks for the update. Glad you figured it out.
