10-06-2006 07:10 AM - edited 03-03-2019 02:15 PM
hi guys,
how can i advertised only default routes to my peer?
tnx
10-06-2006 07:16 AM
it can be done with:
neighbor 1.1.1.1 default-originate
In case this should be the only route sent, add a prefix-list permitting only 0.0.0.0/0
neighbor 1.1.1.1 prefix-list DefOnly out
prefix-list DefOnly permit 0.0.0.0/0
Hope this helps! Please rate all posts.
Regards, Martin
10-06-2006 07:26 AM
Hi Martin,
Got it already. Lazy me. tnx for all the help.
jeff
10-06-2006 07:31 AM
Probably took longer to post and reply than to use CCO search ;-)
Anyhow, this is what the forum is here for ... I mean to help, not to support lazyness.
Have fun, Martin
10-06-2006 07:46 AM
hi martin,
I already tried it before posting, i just forgot to "clear ip bgp", thats why it took me awhile to see the effects. anyways, tnx a lot. =0)
jeff
10-06-2006 09:36 AM
Some other ways to inject the default in BGP:
1-
router bgp x
network 0.0.0.0
Make sure you have the default route in the RIB.
2-
router bgp x
redistribute
default-information originate /* to allow redistribution of the default route in BGP*/
Make sure you have the default route in the RIB (either static or from the specific routing protocol).
Hope this helps,
