How to block RDP Access from a Router
kumar86rakesh
We have a mail server on which  we have two NIC installed one NIC use for public and other one use for private network.
On public network int we have given a static IP which is provided by our ISP and its directly connected with a WAN Router.
On private network int we directly connected our primary mail server.
So is there any option to block Server RDP from Router side because everyday some outsider try to connect our server.
We have tried to block RDP from windows firewall but its not worked.
On router we have added below command to block RDP but its not worked.
ip access-list extended icmp
 permit tcp any host 10.XX.XX.XX eq 3389  (primary mail Server IP)
 deny   icmp any any echo
 deny   tcp any host 12.XX.XX.XX eq 3389 ( Secondry mail Server IP on which we want to block RDP from outside)
 permit ip any any
Please help me out this problem.
Thanks & Regards
Rakesh Kumar
Seb Rupik
Hi there,
What interface have you configured this ACL on and how is the access-group statement written?
cheers,
Seb.
Hi Rupik,
We dont use any acccess list on WAN router and I am also not very expert about router operation and this router was configured by our ISP.
Please find the attached sho run result for better understanding.
ROUTER#sho run
Building configuration...
Current configuration : 1459 bytes
version 12.4
no service pad
hostname ROUTER
boot-start-marker
boot-end-marker
enable secret 5 skld;jfe958049rlkj908989zxz.
enable password abcdef
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
ip domain name abcde.com
username cisco privilege 15 secret 5 skld;jfe958049rlkj908989zxz
interface FastEthernet0/0
 description ### Lan Pool ##
 ip address 12.XX.XX.XX 255.255.XX.XX
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0
 description ### Airtel Uplink ###
 ip access-group icmp in
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip route 125.XX.XX.XX  255.255.255.240 125.XX.XX.XX
no ip http server
 permit icmp host 10.XX.XX.XX  any
 permit tcp any host 10.XX.XX.XX  eq 443
 permit tcp any host 10.XX.XX.XX  eq www
 deny   tcp any host 125.XX.XX.XX  eq 3389
 permit ip any any
no cdp run
control-plane
line con 0
 password abcdef
 login
line aux 0
line vty 0 4
 password abcdef
 login local
 transport input all
end
Hello again,
The 'permit ip any any' statement makes much of your ACL redundant. With it there is no need for for any of the 'permit' statements. I suggest you remove it so that the implicit deny is restored.
If you think that you need it, can you provide the output of 'sh ip route'. Perhaps external devices are able to connect to the internal 10.XX.XX.XX address.
cheers,
Seb.
Hello
Not sure I understand this configuration, Do you have overlapping addressing here or do you have two allocated public address scopes from the ISP?
Interface FastEthernet0/0
res
Paul
Kind Regards
Paul
