How to Bypass NAT (MASQ)?
tophpayas
Is possible to bypass NAT_MASQ in Cisco Router?
Here's my proposed network diagram:
thanks, thanks!
Toph Payas
8 Replies 8
lgijssel
Level 9
Level 9
Yes, this is possible.
You can tweak the nat rules in many ways. However, from your scheme it looks like the internet router is not on a nat outside interface.
We need to see the config in order to give more detailed hints.
regards, Leo
tophpayas
Hi Leo,
Thanks for the immediate response, what do you mean by internet router is not on a NAT outside?
Attaching another jpeg for your reference:
thanks, thanks!
Toph Payas
lgijssel
Level 9
Level 9
Your internet access is at 192.168.1.2, this is the same network as your def-gw (1.1)
To perform nat in the router, traffic needs to pass through it.
From a nat inside to a nat outside interface to be precise.
Leo
Hi Leo,
My concern:
Filtering on my firewall is not working because it only seeing the MAC Address of Def GW(192.168.1.1).
any work-around for this scenario?
thanks, thanks!
Toph Payas
lgijssel
Level 9
Level 9
You can still filter on ip addresses...
Or enable icmp redirects on the router. This will make the clients send their internet traffic directly to the firewall.
Leo
Hi Leo,
Please provide steps on how to enable ICMP redirects on Cisco Router?
thanks, thanks!
Toph L. Payas
Sorry but I was posting from my mobile and on that I find it cumbersome to add links or do other things than just enter text.
Now I have started a laptop and I hope the link below will answer your question:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094702.shtml#howitworks
Please rate helpful posts!
Leo
Hi Leo,
I'm attaching another file for your reference, .
Here's the .pkt for a more details info.
The flow will be like this:
HO_PC01  >  Default Gateway: HO_Router(192.168.1.1)  >  HO_FIREWALL(Filtering)  >  Internet Cloud
Is it possible that the request from HO_PC01  >  HO_FIREWALL will still be his own identity?
thanks, thanks!
Toph L. Payas
