How to change the administrative distance of EIGRP?
shan-cao
Hi,I want to change the AD of eigrp by command "ip summary-address eigrp 33 x.x.x.x x.x.x.x 5"configured in interface.But I can't get the related route with AD=5 in the eigrp neighbor.
How about it? Pls help me!!!
pkhatri
Level 11
Level 11
The AD is locally significant to a router. Setting it to 5 using the 'ip summary-address eigrp' command will only affect the AD on the router on which the command is configured.
Instead of doing this, try the following: on the router that the summary is being sent to, enter the following command:
router eigrp
distance 5 0.0.0.0 10 ! the 10 is the ACL being matched
access-list 10 permit x.x.x.x x.x.x.x ! this is the summary route for which you want to change the AD.
For example,
A --- B
If you have configured the "ip summary-address eigrp 33 x.x.x.x x.x.x.x 5" command on A, enter the above distance command on router B, under its EIGRP process.
Hope that helps - pls rate the post if it does.
Paresh
Thanks for your help!:)
