How to change the default Vlan 1002
kevintang
Hi, I know by default the vlan 1002 is used for FDDI. Of couse my 3550 do not have fiber ring interface.
So how to use this vlan for ethernet ?
S1#sh vlan brief
VLAN Name Status Ports
1 default active Fa0/4, Fa0/5, Fa0/6, Fa0/7
Fa0/8, Fa0/9, Fa0/10, Fa0/11
Fa0/12, Fa0/13, Fa0/14, Fa0/15
Fa0/16, Fa0/17, Fa0/18, Fa0/19
Fa0/20, Fa0/21, Fa0/22, Fa0/23
Fa0/24, Gi0/1, Gi0/2
10 DATA_VLAN active
20 VOICE_VLAN active Fa0/4, Fa0/5
30 SERVER_VLAN active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
S1#
thisisshanky
Level 11
Level 11
AFAIK, you cannot change default vlans. You have a 1000 other vlans left, why dont you use them instead.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Hi Kevin,
If you are falling short of vlan you can go for extended range of vlans but you will not be able to change vlan from 1002 - 1005 in 3550 switch which are reserve vlans.
Check this link for more details
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swvlan.htm#wp1394877
Ankur
