11-30-2006 03:47 AM - edited 03-03-2019 02:52 PM
I have a Cisco 871 connected to my DSL i m using it for VPN as well as as a firewall now what i want to do is to check which of my internal user is using which about of bandwidth and some real time monitoring like softwares and web sites he is visiting
11-30-2006 03:51 AM
Hi Imran,
You can try downloading complete solwinds monitoring package and see if that helps you.
Ankur
11-30-2006 04:11 AM
Hi Friend
you can use monitoring tools like Solarwinds, MRTG, Adventnet etc.
Narayan
