How to check BGP Table
cisco8887
Level 2
Level 2
Hi Guys,
What method will you use to see the world BGP table ? I mean what website that you trust ?
I need to check if a public range has been populated from a certain ISP.
Based on above, is there a way to check the registery of IP against organisations ?
Aram
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I use a Looking Glass site.
Believe that can be obtained from the appreciate registration authority.  Start with IANA.
