how to check flash size
sayhi2shashi
how do i check the memroy (flash)
total, consumed and free in cisco 6513 and 6506 cat switch
regd
Shashi
sivakondalarao
Hi Shashi,
Give the show flash: command, it will show you total size available and free.
GG2-2F-LW1#show flash:
Directory of flash:/
2 -rwx 1809872 Mar 03 2005 23:17:54 c3500xl-c3h2s-mz.120-5.WC11.bin
3 -rwx 94370 Dec 18 2001 21:14:29 c3500XL-diag-mz-120-5.WC2a
4 -rwx 109 Mar 01 1993 00:02:13 info
5 drwx 0 Oct 10 2006 07:43:54 sw1
6 -rwx 390 Mar 03 2005 23:18:51 env_vars
7 drwx 640 Mar 01 1993 00:04:04 html
18 -rwx 109 Mar 01 1993 00:04:04 info.ver
19 -rwx 3796 Nov 20 2006 12:57:16 vlan.dat
20 -rwx 25 Mar 02 1993 16:17:36 snmpengineid
21 -rwx 6439 Dec 11 2006 06:45:45 config.text
3612672 bytes total (293376 bytes free)
GG2-2F-LW1#
Please rate this.... if helpful.
SKRAO
Switch>show bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- n
ame
1 .. image 561FAE73 B363D0 28 11232080 Feb 01 2005 17:56:55 +00:00 c
6msfc2-dsv-mz.121-8a.E4.bin
2 .. image E9B73297 CD2114 29 1686724 Feb 01 2005 18:23:09 +00:00 c
6msfc2-boot-mz.121-8a.E4.bin
19062508 bytes available (12919060 bytes used)
Switch>show sup-bootflash:
ame
1 .. image 9B8D35A4 1843F38 27 24919736 Jul 27 2006 01:41:18 +00:00 c
6sup22-psv-mz.121-26.E.bin
7061704 bytes available (24919864 bytes used)
hope it helps ... rate if it does ...
hi Rao,
thanks..
command 'show flash ' can't work on cat 6513,
i got the memory information with 'show file system'
inKKK01#show file systems
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw system:
- - disk rw disk0:
- - disk rw disk1:
* 65536000 18885972 flash rw sup-bootflash:
45814578 0 opaque ro sup-microcode:
0 223657920 opaque wo sup-image:
129004 128148 nvram rw const_nvram:
1964024 1858807 nvram rw nvram:
- - opaque rw null:
- - network rw tftp:
65536000 65536000 flash rw bootflash:
- - network rw rcp:
- - network rw ftp:
- - network rw scp:
15990784 15990784 flash rw dfc#11-bootflash:
inKKK01#
can u tell me is the 64Mb is the my total flash, or there are partinioned one ? can u pls let me know.
regds
Shashi
