How to config 4PE with SRv6 in IOS-XR
Kagamigawa
https://www.ietf.org/id/draft-ietf-bess-ipv6-only-pe-design-00.html#name-test-3-e2e-ipv6-only-pe-ce-
                               ________
     IPv6-Only       _____    /        \                 IPv6-Only
      PE / CE       /     \__/          \___              PE / CE
  |    |  |    |  |                          |_      |      |   |     |
  | CE |--| PE |--\         IPv6-Only Core      |----|  PE  |---|  CE |
  |    |  |    |    \0=========Underlay =======0|    |      |   |     |
  +----+  +----+     \                        __/    +------+   +-----+
  IPv6 BGP peer       \     MPLS / SR domain /         IPv6 BGP peer
  IPv4 forwarding      \__         __       /          IPv4 forwarding
  IPv6 forwarding         \_______/  \_____/           IPv6 forwarding
Figure 9: Test-3 E2E IPv6-Only PE-CE, Global Table over IPv6-Only Core (4PE)
Cisco, Juniper, Arista, Nokia, Huawei code and platform and test results.
Cisco: Edge Router- XR ASR 9910 IOS XR 7.4.1, Core Router- NCS 6000 7.2.2, CRS-X 6.7.4
Juniper: Edge Router- MX platform MX480, MX960, Core Router- PTX Platform PTX5000, PTC10K8 (JUNOS and EVO) Release 20.4R2
Tested v4 edge over v6 core in a virtual setup using vMX platforrm and 20.4R2 and LDPv6 as underlay, but there were some data plane forwarding issues. Tested same setup on latest release 21.4 and it worked. Investigating what the minimum version is for this setup to work.
Arista:
Nokia: Edge and Core-7750 Service Router, Release R21
Huawei: Edge and Core-VRPv8, Release VRP-V800R020C10
According to the description in this article, the current ios-xr system can achieve 4PE
I used the following platforms for testing:
topology diagram:
platform information:
Cisco IOS XR Software, Version 7.4.1
Copyright (c) 2013-2021 by Cisco Systems, Inc.
Build Information:
Built By : ingunawa
Built On : Wed Aug 4 04:18:28 PDT 2021
Built Host : iox-ucs-012
Workspace : /auto/srcarchive17/prod/7.4.1/xrv9k/ws
Version : 7.4.1
Label : 7.4.1-0
PE1's configuration:
hostname PE1
logging console informational
interface Loopback0
 ipv6 address 2001:db8:cafe:aaaa::1/128
interface GigabitEthernet0/0/0/1
 ipv6 enable
interface GigabitEthernet0/0/0/2
 ipv4 address 10.224.72.1 255.255.255.0
router isis underlay
 is-type level-2-only
 net 49.0192.0168.0255.0001.00
 log adjacency changes
 address-family ipv6 unicast
  metric-style wide
  segment-routing mpls
 interface Loopback0
   prefix-sid index 1
end
P's configuration:
hostname P
interface Loopback0
 ipv6 address 2001:db8:cafe:bbbb::1/128
 ipv6 enable
 ipv6 enable
 net 49.0192.0168.0255.0002.00
  metric-style wide
 interface Loopback0
   prefix-sid index 2
end
PE2's configuration:
hostname PE2
interface Loopback0
 ipv6 address 2001:db8:cafe:cccc::1/128
 ipv6 enable
 ipv4 address 10.224.4.1 255.255.255.0
 net 49.0192.0168.0255.0003.00
  metric-style wide
 interface Loopback0
   prefix-sid index 3
end
MPLS forwarding table on PE1:
RP/0/RP0/CPU0:PE1#sh mpls forwarding
Wed Dec  1 07:35:27.096 UTC
Local  Outgoing    Prefix             Outgoing     Next Hop        Bytes
Label  Label       or ID              Interface                    Switched
16002  Pop         SR Pfx (idx 2)     Gi0/0/0/1    fe80::5209:abff:fe00:704   \
        10282
16003  16003       SR Pfx (idx 3)     Gi0/0/0/1    fe80::5209:abff:fe00:704   \
        3970
24000  Pop         SR Adj (idx 1)     Gi0/0/0/1    fe80::5209:abff:fe00:704   \
24001  Pop         SR Adj (idx 3)     Gi0/0/0/1    fe80::5209:abff:fe00:704   \
When I try to configure BGP on PE1, I get an error:
router bgp 64512
 bgp router-id 192.168.255.1
 bgp log neighbor changes detail
 address-family ipv4 unicast
  redistribute connected
  allocate-label all
 neighbor-group 4PE
  remote-as 64512
  update-source Loopback0
  address-family ipv4 labeled-unicast
 neighbor 2001:db8:cafe:cccc::1
  use neighbor-group 4PE
% Failed to commit one or more configuration items during a pseudo-atomic operation. Al
l changes made have been reverted. Please issue 'show configuration failed [inheritance
]' from this session to view the errors
RP/0/RP0/CPU0:PE1(config)#RP/0/RP0/CPU0:Dec  1 07:37:41.513 UTC: bgp[1078]: %ROUTING-BG
P-3-INIT_GET_VALUE : Failed to obtain Instance ID: bpm/info/default/inst-id during init
ialization: 'sysdb' detected the 'warning' condition 'A SysDB client tried to access a
nonexistent item or list an empty directory'
Wed Dec  1 07:40:17.521 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
router bgp 64512
 neighbor-group 4PE
!!% Change would result in neighbor (2001:db8:cafe:cccc::1) being activated with an invalid address family
end
What caused this?
3 Accepted Solutions
Harold Ritter
Hi @Kagamigawa ,
What is reported in this document is SRv6. This is different from the configuration you posted, which is SR MPLS. Here's a sample configuration to implement 4PE (ipv4 over SRv6).
hostname PE1
vrf test
import route-target
109:1
export route-target
109:1
interface Loopback0
ipv6 address 2001:db8:12ff::2/128
interface GigabitEthernet0/0/0/0
vrf test
ipv4 address 192.168.12.2 255.255.255.0
ipv6 enable
router isis SRv6
net 49.0001.1921.6810.0002.00
segment-routing srv6
locator LOC0
interface Loopback0
passive
point-to-point
router bgp 109
bgp router-id 192.168.100.2
address-family vpnv4 unicast
vrf all
locator LOC0
neighbor 2001:db8:12ff::4
remote-as 109
vrf test
rd 109:1
segment-routing
srv6
locators
locator LOC0
prefix 2001:db8:12ff:2::/64
end
hostname P1
interface Loopback0
ipv6 address 2001:db8:12ff::3/128
ipv6 enable
ipv6 enable
router isis SRv6
net 49.0001.1921.6810.0003.00
metric-style wide
interface Loopback0
passive
point-to-point
point-to-point
end
hostname PE2
vrf test
import route-target
109:1
export route-target
109:1
interface Loopback0
ipv6 address 2001:db8:12ff::4/128
ipv6 enable
vrf test
ipv4 address 192.168.45.4 255.255.255.0
router isis SRv6
net 49.0001.1921.6810.0004.00
locator LOC0
interface Loopback0
passive
point-to-point
router bgp 109
bgp router-id 192.168.100.4
vrf all
locator LOC0
address-family vpnv6 unicast
vrf all
locator LOC0
neighbor 2001:db8:12ff::2
remote-as 109
vrf test
rd 109:2
segment-routing
srv6
locators
locator LOC0
prefix 2001:db8:12ff:4::/64
end
unfortunately, this config above is not correct for 4PE,
4PE means global routing table, not vrf.
BGP should look like this(also adding a piece with global IPv4)
router bgp 109
locator LOC0
locator LOC0
remote-as 109
encapsulation-type srv6
Hi @Kagamigawa ,
Here are the configurations for PE1, P1 and PE2 for 4PE.
hostname PE1
interface Loopback0
 ipv6 enable
router isis SRv6
   locator LOC0
 interface Loopback0
  passive
  point-to-point
router bgp 109
   locator LOC0
  network 192.168.12.0/24
  remote-as 109
segment-routing
 srv6
  locators
   locator LOC0
    micro-segment behavior unode psp-usd
    prefix fc00:0:1::/48
hostname P1
interface Loopback0
 ipv6 enable
 ipv6 enable
router isis SRv6
   locator LOC0
 interface Loopback0
  passive
  point-to-point
  point-to-point
segment-routing
 srv6
  locators
   locator LOC0
    prefix fc00:0:3::/48
hostname PE2
interface Loopback0
 ipv6 enable
router isis SRv6
   locator LOC0
 interface Loopback0
  passive
  point-to-point
router bgp 109
   locator LOC0
  network 192.168.45.0/24
  remote-as 109
segment-routing
 srv6
  locators
   locator LOC0
    prefix fc00:0:2::/48
9 Replies 9
it looks like it is complaining about the ipv4 labeled-unicast being configured under the ipv6 address family.
neighbor-group 4PE
remote-as 64512
Too bad the document you are referring to does not have the actual, vendor-specific configs. What if you change 'address-family ipv4 labeled-unicast' to 'address-family ipv6 labeled-unicast' ?
I think this location cannot be changed. SRv6 provides only the top label of the stack when encapsulating data. Now it needs the 'address-family ipv4 labeled-unicast' of MP-BGP to provide a label to update the bottom of the stack.
Harold Ritter
Hi @Kagamigawa ,
hostname PE1
vrf test
import route-target
109:1
export route-target
109:1
interface Loopback0
vrf test
ipv6 enable
router isis SRv6
locator LOC0
interface Loopback0
passive
point-to-point
router bgp 109
vrf all
locator LOC0
remote-as 109
vrf test
rd 109:1
segment-routing
srv6
locators
locator LOC0
end
hostname P1
interface Loopback0
ipv6 enable
ipv6 enable
router isis SRv6
metric-style wide
interface Loopback0
passive
point-to-point
point-to-point
end
hostname PE2
vrf test
import route-target
109:1
export route-target
109:1
interface Loopback0
ipv6 enable
vrf test
router isis SRv6
locator LOC0
interface Loopback0
passive
point-to-point
router bgp 109
vrf all
locator LOC0
vrf all
locator LOC0
remote-as 109
vrf test
rd 109:2
segment-routing
srv6
locators
locator LOC0
end
router bgp 109
locator LOC0
locator LOC0
remote-as 109
Thanks this is what I need
hello could you post the whole configurations PE1 PE2 and P device
Hi @Kagamigawa ,
hostname PE1
interface Loopback0
 ipv6 enable
router isis SRv6
   locator LOC0
 interface Loopback0
  passive
  point-to-point
router bgp 109
   locator LOC0
  remote-as 109
segment-routing
 srv6
  locators
   locator LOC0
hostname P1
interface Loopback0
 ipv6 enable
 ipv6 enable
router isis SRv6
   locator LOC0
 interface Loopback0
  passive
  point-to-point
  point-to-point
segment-routing
 srv6
  locators
   locator LOC0
hostname PE2
interface Loopback0
 ipv6 enable
router isis SRv6
   locator LOC0
 interface Loopback0
  passive
  point-to-point
router bgp 109
   locator LOC0
  remote-as 109
segment-routing
 srv6
  locators
   locator LOC0
Thank you for your team's response
You are very welcome @Kagamigawa and thanks for the feedback
