How to configuration Default route And NAT on ASA firewall 5500 series
How to confugtion Defualt route Amd NAT on ASA firewall 5500 series , ISP device assigend to my LAN using VLAN , I Have not Public Ip address how to confugtion ISP 's VLAN address as Defualt ip And confugtion NAT ?
regards
Habtemariam
5 Replies 5
balaji.bandi
In this video i want to show all of you about : How to Configure NAT on Cisco ASA with ASDM. For More Video : https://www.youtube.com/my_videos?o=U
Hello
You can use after-auto section 3 nat on the ASA.
route outside 0 0 x.x.x.x <next hop ip address>
nat (inside,outside) after-auto source dynamic any interface
Kind Regards
Paul
routing
route OUT 0.0.0.0 0.0.0.0 <Router IP>
NAT
NAT(IN,OUT) dynamic interface
Hello
@MHM Cisco World wrote:
NAT
This will work however it will default to section 1 nat, and with the three nat sections of the ASA, section 1 takes preference, so if the requirement for more specific manual nat statement is added in the future it could become obsolete and not work if preference wasn't given to it within section 1 over the default pat statement, hence its suggested to append a default pat statement at the very end of the ASA nat order (section 3)
Kind Regards
Paul
Yes you are right but I dont thing he use manual NAT for 1:1 NAT or static PAT.
