How to configure 2811
tunemore1
we like to upgrade from 2501 to 2811 router
here is config sample on 2501
interface Ethernet0
ip address 172.16.1.254 255.255.255.0
ipx network FAFE
interface Serial0
ip address 192.168.70.2 255.255.255.0
encapsulation frame-relay
ipx network 1111
frame-relay map ipx 1111.0000.1111.2222 100 broadcast
frame-relay map ip 192.168.70.1 100 broadcast
Our new 2811 has 16-port switch module and how should I configure old ethernet config on new 2811. Again, 2811 has switch moudule in it.
Thanks in advance,
Tune
thisisshanky
Level 11
Level 11
What was the router connected to before (2501) ? 2501 has 10 base T, so its speed is 10mbps and half-duplex. When you move to new module, what ever that was connected to 2501 should also change its speed duplex to 100mbps / full (or else if that device is not capable of 100
int fa0/1
switchport mode access
switchport access vlan 1
int vlan 1
ip add 172.16.1.254 255.255.255.0
ipx network FAFE
You might need Advanced IP services or Enterprise services feature set IOS to run IPX on the 2800
int s0/0/0
ip add <> <>
service-module t1 timeslots 1-24 speed 64
encap frame-relay
ipx network <>
frame-relay map <>
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
