How to configure ASA5505 to permit mysql traffic
bklepac
I have an application behind an ASA 5505 that needs to access a mysql database over the Internet.  How do IO configure the ASA to allow this remote mysql connection?
Thanks Bill K.
manish arora
Level 6
Level 6
Hi Bill,
Normally the firewall settings allow all traffic from high security interface to low security interface but if you have ACL on the inside ( high security ) interface , then you will have to punch a hole in those ACL's.
Would be better if you can post sanitized configuration from your 5505.
Manish
