how to configure cisco 857's firewall to allow access from LAN?
scorpion1118
i have a server with a private ip of 192.168.0.2, and NAT http port 80 to 192.168.0.2 so the outside world can access the web...
but my computer on the same lan as the server cannot use the domain name or public ip to access the web...i must use the http://192.168.0.2 to access. how to configure cisco 857 so i can use http://mydomain to access?? thanks!!!!!
Jennifer Halim
From internal network, you would need to use the private IP as the public IP is a virtual IP and NATing only happens when traffic actually traverse the LAN and the WAN/Internet interface. If you are from the LAN network, you would not traverse through the WAN/Internet interface hence it's not working when you are connecting to its public IP.
I would suggest that you resolve the domain name to private IP if you have an internal dns server when you are connected to your internal network.
Jennifer Halim
i had though that before,, but then every time i add the host record, i need to add in two places.... and if i update sub domain pointed to somewhere else, i need to update in two places too... isn't there a better way to accomplish this?
