How TO Configure DHCP
Tompeshwar Lal
we have 4 department Finance, Marketing, HR, contracts. All are in different subnet. We need to install a single DHCP server to provide IP for all subnets.
We have one Layer 3 switch Cisco WS-C6513-E; Windows server 2003 DHCP server.
How to design the network ?
Inline image 1
mahmoodmkl
Level 7
Level 7
u need have svi's for the corresponding vlans n configure the scopes on the dhcp server.after tht under each svi configure ip helper address to be ur dhcp server ip address
mahmoodmkl
Level 7
Level 7
how to create SVI  on switch????????
I assume they already exist.
A SVI ("Switch Virtual Interface") is the Layer-3 interfaces of a VLAN:
! L2-VLAN:
vlan 10
! SVI (L3)
interface vlan10
ip address x.x.x.x m.m.m.m
ip helper-address y.y.y.y (DHCP-Server)
From the client's perspective, the SVI's IP-address is the default-gateway.
More information about the DHCP realy-agent you can find here:
http://www.cisco.com/en/US/docs/ios/12_4t/ip_addr/configuration/guide/htdhcpre.html
Hope that helps
Rolf
