How To configure DMVPN cisco 819 Router
ahmedtallat
we have Remote site with Cisco C819HGW+7-E-K9 and we HO with the Router CISCO3925-SEC/K9
we need to make DMVPN between with, the license we have in the remote router is advsecurity_npe
how we can make the configuration ? because when we try to configure the remote router with CCP it's showing this feature not support
our remote router IOS is 15.2
can anyone know how to configure
adamtodd16
Level 3
Level 3
The 819 should accept DMVPN without issue.
How are you trying to do this in CCP?
What are you seeing when attempting to add the tunnel interface?
Did you try through CLI?
iHi adam
Thank you for you reply
I'm using the cisco configuration professional to configure the DMVPN and it's showing this feature not supported
We used the configuration professional to configure the main router in the head office
If you know how to configure throw cli please send me the steps
