How to configure fail over link between 2 Cisco ASR 1002 router
prem.ce24
Dear Team,
I need to configure ail over link between 2 Cisco ASR 1002 router
So please provide the configuration for same
Thanks  & Regards,
Prem Prakash
Philip D'Ath
You barely provide enough details to help.
You could configure an Etherchannel between them if you can connect them both via a layer 2 circuit.  Etherchannel is particularly simple.  It supports everything that runs over a single bearer.
You could also configure two serpate layer 3 circuits and using a routing protocol, but you need to consider what layer 3 protocols are being used as it will be a more complex configuration.
MANI .P
can you share clearly , the what is your correct requirement ?
