Memory allocation of 16540 bytes
mahmoud.mater
i have cisco 2921 router connected to wireless bridge every 2 days the router it hang and can not access telnet just consol and i got this messeg
*Nov 21 10:49:59.148: %SYS-2-MALLOCFAIL: Memory allocation of 16540 bytes failed from 0x300256C0, alignment 0
Pool: Processor  Free: 2100920  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
 -Process= "qos_mon_periodic Process", ipl= 0, pid= 402
-Traceback= 30010520z 300109F4z 3001F248z 33DA93A0z 334539B0z 334539FCz 33DA7494z 33DA8C18z 33454864z 300329F0z 300329D4z
*Nov 21 10:51:18.744: %AAA-3-ACCT_LOW_MEM_UID_FAIL: AAA unable to create UID for incoming calls due to insufficient processor memory
johnlloyd_13
Level 9
Level 9
hi,
try to perform an IOS upgrade.
thank u but this last version 15.5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Cisco's IOS doesn't implement memory defragmentation, so if you have lots of certain activities, and little free memory, fragmentation can cause there to be insufficient memory allocation errors.  (BTW, so can memory leak bugs.)
Assuming you're not dealing with a bug, the three possible methods to avoid this issue are: reboot on a routine basis (if supported, the warm reload feature will reboot much quicker), add RAM to the device (if possible), reconfigure to reduce activity to reduce memory usage.
