How to configure Hairpin or loopback NAT
dudefoxlive
I am trying to figure out how to get our cpanel server to access itself from its public IP instead of its internal IP. cpanel keeps complaining when autossl trys to renew the certs because its returning its private/internal IP instead of the external IP. We are running a cisco 1941 series router on iOS 15.5(3). Here is a copy the config. Not sure how I need to change it to make this work. our cpanel server is on IP address 172.16.250.10. cpanel says we need to configure hairpin nat or loopback nat.
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname HOST_NAME
boot-start-marker
boot system flash c1900-universalk9-mz.SPA.155-3.M.bin
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 8
logging console critical
enable secret 5 SECRET_PASS
enable password 7 PASSWORD
aaa new-model
aaa authentication login local_auth local
aaa session-id common
ethernet lmi ce
clocl timezone EDT -5 0
no ip source-route
no ip gratuitous-arps
no ip bootp server
ip cef
login block-for 300 attempts 3 within 60
no ipv6 cef
license udi pid CISCO1941/K9 sn SERIAL_NUMBER
archive
 log config
  logging enable
username instructor password 7 PASSWORD
redundancy
no cdp run
interface Embedded-Service-Engine0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 no mop enabled
interface GigabitEthernet0/0
 description
 Outside Interface to LRC
 ip address PUBLIC_IP1 255.255.255.224
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 ip verify unicast source reachable-via rx allow-default 100
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 description Inside interface to classroom
 ip address 172.16.0.1 255.255.0.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 duplex auto
 speed auto
 no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static udp 172.16.104.120 51820 PUBLIC_IP1 51820 extendable
ip nat inside source static 172.16.250.10 PUBLIC_IP2 extendable
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
logging trap debugging
logging facility local2
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 100 permit udp any any eq bootpc
control-plane
banner motd ^Cmessage of the day^C
line con 0
 logging synchronous
 login authentication local_auth
 transport output telnet
line aux 0
 access-class ls_def_acl in
 exec-timeout 15 0
line 2
 exec-timeout 15 0
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class sl_def_acl in
 exec-timeout 5 0
 transport input telnet
scheduler allocate 20000 1000
no ntp allow mode control 3
ntp server 172.16.104.125
end
Hello @dudefoxlive ,
take a look at this thread https://community.cisco.com/t5/routing/nat-hairpinning/td-p/2475807
Regards, LG
*** Please Rate All Helpful Responses ***
I am new to this so I am learning as I go. I am confused by this. Could you provide an explanation as to what each line is doing? I don't know which is internal lan and external wan in the example nor do I understand what the ip address 192.0.2.1 255.255.255.0 secondary is.
I understand and in this case I would suggest taking a look at the CCNA certification https://www.cisco.com/site/us/en/learn/training-certifications/certifications/enterprise/ccna/index.html#tabs-35d568e0ff-item-194f491212-tab
which will teach you the basics of networking starting with IP addressing, switching, routing, Network Address Translation (NAT) and many more technologies used in todays communication infrastructure world.
Regards, LG
danielbrown8998
  1. Modify NAT Rules to Allow Internal Access via Public IP
    Add the following rule to enable hairpin NAT:
    shell
    CopyEdit
    ip nat inside source static 172.16.250.10 PUBLIC_IP2 extendable ip nat outside source static PUBLIC_IP2 172.16.250.10 extendable
    Ensure NAT Reflection is Enabled
    This allows internal hosts to resolve the public IP properly.
    Adjust ACLs if Necessary
    If you have restrictive access lists, make sure they permit traffic from the internal subnet to the public IP.
    Flush NAT Translations (If Needed)
    After applying the changes, clear existing NAT translations:
    shell
    CopyEdit
    clear ip nat translation *
    Now, when your cPanel server tries to reach itself using its public IP, the router will properly redirect the request. For a more in-depth guide, check Cisco's official NAT documentation.
